Nokia Default Codes
Most Nokia phones have the same default codes.The default code is entered for the first time on a new Nokia phone and it won't be accepted if the default code has been changed by its owner.
Here are some default codes;
- Security Code: 12345
- Phone Lock Code: 12345
- Standard Bluetooth Pairing Codes: 0000
Nokia Secret CodesThere are a lot of secret codes on the Nokia phone and I'm sure you are aware of it or even know some of it. The listed codes below may NOT work for all the Nokia phones or it is restricted to some Nokia phones but you can try it on your phone to find out. Here are some of the useful codes:
- #pw+1234567890+1# : Information about Provider Lock Status/Sim Restrictions.
- #pw+1234567890+2# : Information about Network Lock Status.
- #pw+1234567890+3# : Information about Country Lock Status.
- #pw+1234567890+4# : Information about Sim Card Lock Status.
- *#06# : Imei number (International Mobile Equipment Identity) or serial no.
- *#7780# : To reset the phone to factory settings.
- *#7328748263373738# : To reset the phone's security code.
- *#92702689# : Details about the phone: Serial no, month and date produced, the date the phone was purchased, date of last repair (0000 if not repaired at all).
- *#0000# : software version.
- *2820# : To add Bluetooth Device.
- *#7370# : To reformat the phone or Hard Reset (usually for Symbian phones).
- *#99# : GPRS Speed dial Code.
- *#746025625# : Details about the Sim Clock Allowed Status.
- *#7370925538# : To Reset Wallet Code (usually for S60 phones)
- *#3925538# : To Delete All Content in Wallet (if it ask for the phone lock code enter your phone lock or the default phone lock code).
- *#9999# : Details about the software version if *#0000# doesn't work.
- *#2640# : To display the Security Code in use.
- *#73# : To Reset the phone's time and also the game scores.
- *#7760# : To display the Manufacturer code.
- *#8110# : Details about the Software Version for Nokia 8110.
- *3370# : To activate Enhanced Full Rate codec (EFR) (which means your phone will use the best soud quality but the talk time is reduced to 5%).
- #3370# : To deactivate the EFR.
- *#4720# : To activate Half Rate codec (which means your phone will use the lowest quality sound but you would get 30% more of talk time).
- *#67705646# : To remove Operator Logo for Nokia 3110 and Nokia 3330.
- *#43#: To view the Call Waiting Status on the phone.
- *#30# : Enable to view the private number.
- *#21# : To check numbers that All Calls are diverted to on the phone.
- *#61# : To check the numbers that On No Reply calls are diverted to.
- *#62# : To check Divert If Unreachable/No Service calls are diverted to on the phone.
- *#67# : To check that On Busy Class are diverted to.
