Gas lights and works for 10 minutes & cuts off before water gets hot. What could be wrong? When we use the electric mode, it gets warm but not hot? Could it be an element? If so where is the element located? I found schematics on-line but did not see element.
If you've checked at pressure relief valve ( careful, not to burn yourself just in case it is hot) by pulling lever and catching some water that comes out in a cup or whatever. If it feels hot out of there, check that by-pass isn't faulty. Not uncommon for valves to seize, and only partially open, or close, and end up mixing hot with cold.
Testimonial: "This was the solution.We did the pressure relieve valve suggestion, also one of the valves was stuck in the wrong position mixing hot with cold.Thanks"
Your elements are located in the front of the unit
I would suspect that your thermostat has gone south
located under the black piece of foam
At 10 years old I normally suggest that you replace the heater
you can end up putting an amount equal to the cost of a new unit
into the old one and not have the warranty
I have an atwood water heater in my RV. The problem is that the gas lights on demand and will continue to operate normally, but the water never gets above warm.
It is on a 2000 model Fleetwood travel trailer.
Do you know how old this heater is? You may have one of several problems Age will help determine which one to start with
