Question about Measuring Tools & Sensors
Acr 2000 ac machine will not leave initializing screen on start up
Posted by delbert011 on
Hasan Khan Amran
    President:
  • 181 Answers
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Posted on Mar 14, 2010
  • 7 more comments
  • Beerbongs123 Mar 29, 2011
    I work at a gm dealer, and we have this machine that had this issue. The reason this happens is due to battterys going dead in the main control boards.(the boards behind the screen). The fix is to remove the boards, then dissasemble them, two of the larger boards have 2325 batterys soldered on them (coin type- 3 volt batterys). Have a PC shop or yourself if your savy with a soldering gun,to replace the batterys then re-assemble. Afterwards the acr 2000 will have to be reprogramed.( I reprogramed mine with a update cd we got in 2002) most gm dealerships should be able to do this.
  • 1969jlo Apr 13, 2011
    How did you get the terminals off the old batteries and reinstalled on the new batteries?
  • hilbert137 Jun 09, 2011
    thanks for the info on the ACR 2000. I replaced the batteries and figured no problem locating a disk. I too work at a GM shop. I could not find ours. I called several other people that I used to work with to check thier GM shops. No one has them anymore. I called a tech assist and was refered to a service center, they tried to email me the program. that did not work. I am now going to send the service center a thumb drive and they will copy the program on the drive and send it back to me. has anyone seen this program downloadable on line?
  • riversideser Jun 15, 2011
    HEY HILBERT,SAME PROBLEM HERE WITH OUR ACR 2000,DID YOU LOCATE THE PROGRAM FOR RESTART? ANY HELP WOULD BE AWSOME!
    RAY,
    RIVERSIDE SERVICE CENTER
  • hilbert137 Jun 18, 2011
    I got the program for the acr 2000 from the service center today. I found that I needed to copy the thumb drive program to a CD, then load the program on a computer running windows 98, then load the acr using the serial port of the pc to the connector on the back of the acr. I am not having very good luck though, As soon as I turn the acr off, it seems to lose its programming.
  • Joe Trotter Jul 08, 2011
    I tried to buy to cd from kent moore but it is on back order until sept. Really like to try it on my machine
  • Anonymous Jul 20, 2011
    email me at [email protected] i have the gm cd i can make copies and send them to whoever needs them just cover shipping. i will need to replace the batteries on my machine. i have been using the cd to reboot the machine to use everytime. hope the batteries will fix my problem also, those boards are very expensive one cost 800.00 from robinair. cell is 773-491-4658 name is john. located in chicago
  • apostoli Aug 06, 2011
    I soldered new batteries on the computer. I connected my laptop with the unit and installed software. The program says turn unit on to begin upload, then I turn it on and nothing happens...no upload. Does anybody have any specific info on the software procedure?
    I soldered new batteries on my unit. I was able to get ahold of the software cd. I installed on my laptop, set com1 to my laptop and the program. Connected a rs232-to-usb adapter on main board port 1 and ran the program. It says turn on unit to begin upload...I do and nothing happens?? Any ideas or recommendations on the procedure?
Adam Brock
    New Friend:
Can anyone send me the software to fix this on an acr2000 machine. I have had a computer shop replace my batteries and checked over the boards and didn't see any issues with the board but it still says initializing system and won't go past that. I really hate to have to pay $450 for someone to basically just flash it and send it back. Any help would be appreciated
Posted on Aug 02, 2020
  • Anonymous Jun 20, 2021
    You ever find software
  • David J
    David J Aug 17, 2021
Peter D'Arche
I know this response is really late, but if any one else is experiencing this issue, we can help. We will repair the board and warranty it as well. http://www.automotiveequipmentparts.com/ACR2000-Board-Repair-p/rob-ra19606a.htm
Posted on Aug 22, 2014
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
2answers
Why does my Westwood T1600 keeps cutting out
I would adjust valves to start.
Apr 30, 2014 • Garden
Beeping Sound
How old is your laptop? When I used to work over computers, laptops had a backup battery as well as a main battery and AC Adapter - could your backup battery be toast?
1helpful
I have a 2000 camaro 3.8 v6,electric fans come on only when a/c is on.sometimes the engine will stall after initial start up.
what about a tuneup--new distributer cap and ign wires--throttlebody cleanin-------the fans start cause of heat from ac
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT
Hope this will help you to solve the problem.
27 hp v twin on exmark z mower, sometimes when starting does not have to be warm happens ive noticed when cold in morning, hit the key and spins like no compression will pop out of the exhaust muffler hit...
hi
remove both exhaust mufflers and clean them of carbon deposit.pay attention at the screens from there(if they exists).try again start the engine
regards savumihai71
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Tom Chichester
ray gallant
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
