Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
I know t sounds obvious but check the fuses. Make sure the power feed wire has not dislodged from the compressor clutch. the is also a relay that may have died, any compitent mechanic that can look at this will analyze the fault quickly. Lastly be sure that none of the air con lines have split or been damaged and lost its gas. Trying to help without seeing, good luck.
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
