Question about Brother MFC-7820N Laser Printer
I cannot get the BACK COVER OPEN message to GO AWAY. I tried to open the back black cover and check to see if there were any paper jam and i also opened the front cover and ejcted the ink toner and no paper jam there either. I un-plugged the mail wire to reset the programe but that doesn't work either. THERE IS NO PAPER JAM AND THERE IS NO COVER OPEN !!!!! HELP !! Printer is MFC 7820N
Posted by simmyg14 on
adi
  • 526 Answers
There is a little cover there that has a sensor flag on it. It is most likely in a jammed position. If you are able to carefully take the cover out, you can bend it slightly, readjust the sensor flag, and reinstall it.
Thanks
Posted on Mar 12, 2010
Anonymous
    New Friend:
This worked for me also.
Posted on Apr 05, 2010
Back cover open message but cover is closed
Sounds like the sensor has been damaged try turning off at wall and re starting if it continues you'll have to go into maintenance mode and reset
Apr 09, 2014 | Brother DCP-7020 All-In-One Laser Printer
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
I had a paper jam and I had opened back cover to clear it. Now when I close it still says Back cover open. Close the back cover. What should I do? There is a black color flap inside the main back cover...
Just fixed the same problem. My solution was as follows: When you open the back cover there is another plastic flap/cover inside that drops. Across this 2nd cover there is a plastic rod running parallel with a plastic finger that sticks up perpendicular to the rod which I believe guides the paper into the roller.
On my machine this rod came out of line, placing it about a quarter inch to the left which affected the sensor and the guide. If you look closely, you will notice a small groove on the rod that needs to be in a specfic slot on the 2nd cover. Good luck
Jun 08, 2010 | Brother MFC-7820N Printer
MFC-7220 All-In-One Laser Printer: the back cover open message will not go away...
There is a paper jam in the machine which is blocking the sensor for the back cover.
Remoev the drum and toner (cartridge) from printer and look inside, there should be a piece of paper there, you need to remove it slowly
May 16, 2010 | Brother MFC-7220 All-In-One Laser Printer
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
Recurrung jam message
if there's no paper jammed then a sensor might be dirty, the printer has several sensor along the path of the paper to detect its flow.
Mar 30, 2010 | Xerox DocuPrint C525A Laser Printer
Back cover open will not go away ... even though back cover is closed!
This is a common problem with the Brother 7820 printers. If you open the back cover, there is a black tray in front of the fuser roller that falls back. That black tray has an arm on the inside on one side that triggers the back cover open message. try pushing that tray up firmly against the back with the back cover open and see if the message disappears. If it does, try taping folded paper to the rails on inside of the grey back cover. The verital plastic rails are what push the black tray into the printer. By taping the paper on you are adding depth to them which will push the black tray further into the printer. If this doesn't work and you cannot get the message to go away from pushing on the black tray, there may be a problem with the trigger. If this were the case I would replace the printer. You can find the 7820 refurbished for $99 online. Just google 7820 refurb.
Apr 15, 2009 | Brother MFC-7820N Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
441 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
