Question about Fuji FinePix A345 Digital Camera
Install a 2 gb memory chip and camera displays card error
    President:
  • 423 Answers
Your A345 isn't compatible with the 2gb cards, only up to a 1gb xD. Here is a link to Fuji Canada's compatibility chart: http://www.fujifilm.ca/x7970.xml
Posted on Mar 12, 2010
Coolpix p1 formatting problem on new memory disk.
There are 3 options, which come up to my mind :
1) Compatibility
The camera is containing a controller, able to communicate with a inserted memory-card. In some cases the size of the memory-card is not supported by this controller.
2) Protective mode
There's a small slide at the edge of this card. Maybe the slide is set to protect the contents of the memory card.
3) Pin-connections
Sometimes, you don't take care enough about the way you insert a memory card into the camera. Everything goes quick... If you inserted the card wrong, the pins at the menory card wont touch the internal pins in the socket of the camera.
4) Fake memory
There are some fake memory cards sold. This means, inside the card is a FLASH-memory chip and a tiny controller-chip. Some Chinese see it as a sport, to use for i.e. a 4 GB memory-card, replacing the outside cover with a text that states 32 GB. And likewise, they have to re-program the controller-chip, to think it has 32 GB FLASH-memory onboard. So, if you insert this card into a PC with Windows, Windows will show this card is 32 GB, while it is actually 4 GB. There are programs to test memory-cards for this type of fraud. However, most of the time, you can figure it out yourself, by checking the price you paid for this memory-card. If the price for this new card was extremely interesting (read : low priced), you probably burned your fingers.
5) Defective memory
The manufacturing process of memory-chips has it flaws. Luckily they use tests to check batches. If there's some malfunctioned detected, they throw it away. Unluckily, there are workers at those factories, who take these (partly) malfunctioning memory-cards back home and sell them at internet. Dealers just think about earning a quick buck and buyers face the results.
Oct 14, 2013 | Nikon COOLPIX Cameras
Memory card error
This seems to be a known issue with the Canon camera's to display Memory card error.
Give this a try
1. Remove the card from camera and wait for sometime ( 1-2 minute ) and re-inserting the card.
2. If this does not work, you need a card reader to read/view images on your PC ( since you are not able to access the card in your camera )
3. If you are not able to access/view the images from Card, click on the link below to recover the images from card - Recover images
When you open the webpage, click on the Download Now option to download the software ( it is free )
4. Try this fix to resolve the issue, Sometimes it takes long time for the camera to load the images and it results in memory card error - Click on the link to download the fix - Firmware Update
5. Try using a SD card with less memory like 1 GB card or max 2 GB for better access of card in camera.
Hope this is helpful.
Nov 05, 2010 | Canon PowerShot S3 IS Digital Camera
I have a Bushnell trailscout 119900 and it wont accept any other SD card but the one that came with it. The one that came with it is only a 512 MB chip card The ones I have been trying to use are 2 GB SD...
Probably the first thing to try is formatting the card. There should be a function in the setup menus to do this. If it won't format or gives an error when you try the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Oct 30, 2010 | Bushnell Trail Scout 11-9500c Digital...
Why does it say memory card error on the screen
Hi there, For few reason camera showing memory card error.
1. Memory card damaged.
2. your memory card finished is life time storage memory.
3 . virus infected.
4. If your memory card storage capacity more than camera support card then its also show to you. For example your camera support maximum 2 GB card, but your try to use more than 2 GB memory card.
I suggest your remove the memory card and scan by updated antivirus. After that, if not working then fomat it and try.
Thanks & waiting for your feedback.
Feb 15, 2010 | Canon PowerShot SX 200 IS Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
I just received a SanDisk, ElitePro, 32GB memory chip for my Kodak C875 camera. Upon chip insertion LCD says, "disc requires formatting", "continue", "formatting will delete everything on memory card",...
This camera's software will accomidate up to 2 GB SD card, or up to 8 GB SDHC card. Check your camera manufacturer's Help Page to learn the card capacity of your camera
Dec 25, 2009 | Kodak Cameras
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
My Kodak EasyShare C315 needs formatting.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
Fine Pix A900 Memory Card
make sure camera supports a sdhc type card-if not go back to a 2 gb and you will have no probs
May 19, 2008 | Fuji FinePix A900 Digital Camera
Fuji FinePix A345 Digital Camera Logo
227 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
