Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXI Dishwasher a P3 code is flashing, seems to be working alright. Thanks to any help
Posted by gatlinburgbe on
Anonymous
    New Friend:
  • 110 Answers
The p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Posted on Mar 16, 2010
Stoyan Velichkov
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Hi Monomoy,
looks like you are familiar with all those Hobart mixers. Hope you can help me too.
So I have a HL600. Got it from a school. Was working prior to remove from the school facility.
A month later plugged it in. Worked for like 20 min and stopped.
Bowl still goes up and down but there is no lights on the display.
And mixer wont start at all. Called Hobart. They sent out a tech. He checked the mixer and said all is good with it just the control panel board is bad. Ok So I got another board. Same thing. Mixer worked like 20 min and stopped. All the same sypthoms. Now since the tech said its the board thought OK. Let's put another board on it. And same thing happened again. Mixer stopped, lights disapeared.
Now we have 3 mixers and 3 bad boards I guess.
But I don't think the board is the problem anymore. What's the chance that working machine when I take out the board and put it on another unit it won't work.
The problem must be something else.
Please let me know if you have any ideas how to get them back working.
Much appreciated.
Regards Stoyan
Posted on Oct 18, 2019
I have a Hobart LX18C. New control board now turns on, but it says "18H" when it starts up and shows a P3 error code. I think it's confused because it's a C model (low temp) not H (high temp).
Error P3, Rinse Tank Booster Thermister is faulty
SOLVED: Hobart LXI Dishwasher a P3 code is flashing ...
https://www.fixya.com > support > t4318217-hobart_lx...
Mar. 11, 2010 - It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you ... 1 answer · 11 votes: The p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ...
SOLVED: What is p3 code on hobart am15 dishwasher - Fixya
Sep. 2, 2019
SOLVED: What does a P3 code mean? On a Hobart LXI high ...
Jan. 5, 2014
My hobart am15 display a p3 error code and i make - Fixya
May 1, 2010
SOLVED: Error code "p3" appears in the digital panel with a ...
May 12, 2010
More results from www.fixya.com
18H doesn't exist
https://www.google.com/search?q=hobart+lx18c+18H+error+code
I have a Hobart Dishwasher model LX30, it seems to stall when in the fill cycle from the start, which blocks any further function except shutting down, on the screen there appears a wrench insignia.
Hobart LX30H ML 104354 Manual Page 28
According to the manual ... the wrench icon comes on with OTHER codes for the LX30. Did you get a flashing P1, P2 or P3?
Or for that matter, get any associated E codes to come up?
Depending on the P or E codes there are fixes discussed on prior Fixya answers for this machine ... search there for more help
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 • Dishwashers
2helpful
WE LOST OUR MANUAL AT WORK AND HOBART LXH DISHWASHER KEEPS SHOWING DELIME , HOW CAN GET THIS GO AWAY, THANKS
Use a commercial deliming agent (like Lime Away or LSR). Remove the rack from the dishwasher and close the door. Press Off to power down the machine. Next press and hold Wash (Delime) while pressing ON. Delime should show in the display. The unit will fill with water and then flash Add and Delime. Open the door and add the deliming agent according to the directions. (The sump holds about 3 gallons of water.) Close the door and press Wash (Delime). The machine will start the wash mode for 5 minutes and then do two rinse and drain cycles. Delime symbol will flash while this takes place. When finished, the power to the control will be turned off. Check the interior of the machine for lime deposits. If needed, repeat the delime cycle. If the delime program is interrupted before it is completed, then start the delime process from the beginning.
The manuals and other documents are available to registered users of the Hobart site here: https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2Fdefault.aspx&reason=0&formdir=2 . The direct link is: hobart.co.kr/install_pdf/040.pdf .
The spec sheet is available here: http://www.hobartcorp.com/products/warewashing/undercounters/lxi-undercounter/ .
I hope this helps.
7helpful
2answers
Error code "p3" appears in the digital panel with a little tool diagram. The rinse cycle doesn't work..
That code is for the booster . probably the thermistor .. if there is a hobart service center in your area, you could get one there and instructions on how to replace.
Please vote!
18helpful
2answers
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
3helpful
Wrench and code p3 display
this is a probe booster error your probe failed replace it
Top Hobart Dishwashers Experts
Marvin
Marvin
Narseman
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
