Sony SDM M51 15.1" LCD Monitor Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Srtyws how do I get the "no input signal" box to shut off when my computer shuts off? I have two more of these same SDM-M51 Sony monitors and neither does this. the box stays on even when the computer is off and all cables are connected, nice picture when it is on, so no problerms there, just can't get that box to shut off when I power off. tried hooking up to a couple more computers and laptops with the same result. help if you can.
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262654
Points
1837
The cheapest method of all.
Make sure your PC is plugged into a power strip and after windows shuts down just hit the off switch on the power strip.
Unless you want to shell out some cash for a new power board for your monitor.
SONY SDM S81R
hello sir,,
since there is a problem with the monitor..u have to contact the sony vendor ,
u can contact them in 800-326-9551
n also 888-476-6972..
thank you
have a great day
I have one old moniter on model of sdm m51d wheather it can be used for seeing elivision
The monitor does not have an input for composite signal of video or audio or the RF input .
So this is a long way out to convert the set as you will require a conversion with a higher cost which is not worth or else it has to be used with a PC using a tuner board.
2answers
ETI information box appears on SONY SDM-HS95 monitor repeatedly
You might try checking you monitor setup, you should be able to shut it off by unckng the proper box
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
3helpful
How do i reset my SDM-HS75P monitor information box keeps popping up
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Black screen with message about no input signal
might be something wrong with your monitor's data cable
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
7helpful
2answers
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
