Question about Jensen VM9510 Car DVD Player
My dvd player screen always pops up with the jenson screen and STOP in the top right corner. How do I get back to the "it is unlawful to drive while dvd.." screen?
    New Friend:
  • 37 Answers
Hookup the acc wire so it powers off with the key
Posted on Mar 17, 2010
Why does my DVD player say STOP in Upper Right Corner?
Sounds like your laser mechanism is no longer capable of reading a disk. If it does it with other disks then you can be sure of the diagnosis.
And due to parts cost and labor a repair is usually not cost effective.
Apr 28, 2012 | Magnavox DP170MW8B DVD Player
Jensen DVD player (JDVD 4301) does not show picture when DvD is inserted. Message on screen "Warning Stop Watch Video" display on blue screen although I can hear the movie playing. Did I connect...
Jenson requires the green wire to be connected to the vehicle parking brake.(Safety feature) this green wire requires a negative switch to activate the screen.
Jul 29, 2011 | Car Audio & Video
My Sharp Aquos blue ray player won't read all blue ray dvd's, why
You need to force the player to the the Top Menu of the disc.
The way to do this is: load disc, wait until it says "Reading Completed" (about 1 minute).
Wait for the PLAY icon ">" to show in the upper right corner (this may take up to 30-40 secs).
Once you see the ">" Hit the STOP button on the remote to get to the player's splash screen.
From the Sharp splash screen Hit the "Top Menu/Title List" button on the remote and wait for the circulating dots and then the disc menu appears.
Play the movie from the menu and you should be good to go.
~JC
Jul 16, 2009 | Sharp BDHP20U Blu-Ray Player
BYPASS EMERGENCY BRAKE WIRE
unhook your E-Brake wire and do the following:(2 options depending on DVD Unit)
If you have the old firmware then all you need to do is ground the parking brake wire
OR
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 28, 2009 | Phase Linear UDV9010 Car DVD Player
Pioneer touch screen dvd/cd player
Press the reset button. It is the tiny button flush to the surface on the top right hand of the faceplate. Goodluck.
Jun 08, 2008 | Pioneer AVIC-N2 Car DVD Player
Need setting to change regional code on samsung DVD P172
This works to change region code 5.
This is how it works.
1)Power on player.
2)Ensure that there is no DVD inside the player.
3)The tray should be closed.
4)Press "Subtitle" on the remote control.
5)Press 53814 for region 5 (For other regions see any of the other cracks)
6)The region code 5 will be displayed on the left top corner of your screen.
7)Now press 9. A 9 will be displayed on the top left corner of the screen.
8)Press Subtitle on the remote again
9)Power off the player.
10)Power it on again and you are region independent!!
Worked for me.
Mar 13, 2008 | Samsung DVD-HD870 DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dvd player on Jenson VM9311TS
well if u haven't fixed it yet this is what u do. now that u have the toggle switch and that blue screen is gone ,now u put that code in . u put a dvd in when it starts u press stop twice on the remote then press1264 . as soon as u put in that last number a menu will appear on the screen that says
this what u should have it at if not then change it to this
REGION:1
BRAKE OVERRIDE: ON
MACROVISION: OFF
Dec 23, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
43 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
