Codes for telewest north east march 2010
You will need to reset your starview box to factory settings first which can be done through the main menu, type 0000 when prompted for code.
Reboot the box as you did when you first got it.
Don’t forget to turn “Key EMU” back on as this will have changed to off with the reset (1570 from the menu screen).
This should have cured all your problems!!
If this still doesn’t work you will need to input new codes via Nagravision (also 1570 from the menu screen).
PROVIDER CODE: 5A 01
KEY 00 = CF 53 0C 33 79 61 71 85
KEY 01 = 52 5E 8D 45 FC 75 F6 4A
There is a rumour on the streets that Telewest are soon to dump Nagravision and send out all Telewest users new cards!
Don’t know if this will ever happen, but if it does how will we enter new codes???
I lost my channels last night and used codes above which did not work until i entered them and then autoscanned the channels again now i have my channels back so its worth a try
Pls i need t.w code if any one got one new code 28/3/2010
All this nagra 3 is **** i just put in codes and my box super starview 3 and it works fine the new codes are as follows
00-B0,B8,4F,04,E6,5F,87,80.
01-A3,EB,EC,07,D6,49,D2,EB.
So ignore folks saying"throw you box its the dreaded nagra 3" it is not here yet.
I can not use my d digital box since last 6 hrs ........... any one got new code pls \\\\\\\\\\\\\\\\\//////////////////// ?
Codes for tw 5a 01 april 8th 2010
if these codes still don't work try inputtin the old codes as i have had to do and its working fine again now... these codes are only if old codes still don't work
hope this helps
My box also went off yesterday and is not working with the code above, does anybody know if there are codes for telewest south east
Just go back 2 factory settings and re scan ? should be working now
Telwest codes for midlands anyone?
Please,does anyone have the new codes for euro/vax max in the edinburgh area
Nagra 3 coming to everyone once you get new vm card you have approx 2 weeks before all boxes are uesless
