Using a wood chisel or screwdriver, remove the rubber molding around the windshield. Then, from inside the car, put a firm/steady pressure on the glass. It should lift out. clean ALL of the black adhesive caulk from the metal frame and install new black caulk. Press in the new windshield - and reinstall the rubber molding.
WINDSHIELD WIPERS
It
can be faulty wiper motor or blown wiper control fuse.
Do
you hear any kind of noise when you starter the wiper function. If yes then
fuse is ok, but issue is wiper motor.
If
no movement at all and no noise then its blown fuse or shorted/loose wiper
control wiring: -----
For
complete troubleshooting i suggest you few helpful links with accurate
solutions.
Click
the link below: -------
1993 Ford F350 wipers not working?
http://repairhelpcenter.blogspot.in/2012/02/1993-ford-f350-wipers-not-working.html
How to Replace a Windshield Wiper Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-windshield-wiper-motor.html
Wipers not working, but hear relay click on Lincoln LS?
http://schematicsdiagram.blogspot.com/2011/12/wipers-not-workingbut-hear-relay-click.html
Car windshield wiper gets power for movement and stops?
http://schematicsdiagram.blogspot.com/2011/12/car-windshield-wiper-gets-power-for.html
How does cars Windshield Wiper System Works
http://technoanswers.blogspot.com/2011/11/how-does-cars-windshield-wiper-system.html
1997 Honda Protege: Replace Wiper Transmission?
http://technoanswers.blogspot.in/2012/06/1997-honda-protege-replace-wiper.html
Windshield wiper fluid container leaking?
http://whatisbyme.blogspot.in/2012/05/windshield-wiper-fluid-container.html
Where is wiper fuse located on1993 chevrolet suburban
http://technoanswers.blogspot.in/2012/02/where-is-wiper-fuse-located-on1993.html
2002 Toyota Sienna: Wipers and Passenger side Power window
stopped working?
http://technoanswers.blogspot.in/2012/04/2002-toyota-sienna-wipers-and-passenger.html
Complete wiper components replacing details for Acura Car
Models?
http://repairhelpcenter.blogspot.com/2011/11/complete-wiper-components-replacing.html
These details will help.
Thanks.
hear relay click?
http://schematicsdiagram.blogspot.com/2011/12/wipers-not-workingbut-hear-relay-click.html---------
Where is wiper fuse located?
replacing details for Car Models?
The wipers not working?
How to Replace a
hear relay click?
http://schematicsdiagram.blogspot.com/2011/12/wipers-not-workingbut-hear-relay-click.html-----------
replacing details?
This will help.Thanks.
