Televison & Video Logo
My alba 19 inch lcd tv's picture looks like a negative unless it is viewed straight on.if you look at it even slightly off-centre the picture looks negative.looking straight on at eye level the picture is perfect.is this normal as i have many other tv's and have never experienced this before?should i take it back to argos?
Posted by elizabeth525 on
Larry
  • Televison & ... Master
  • 4,805 Answers
No its not normal but I have to admit Ive never seen this before and Ive been working on TV's since they were vacuum tube sets
Posted on Nov 27, 2017
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Picture looks like photo negative when power is reapplied
the most probable problem is it would be one of the first generation LCD televisions.
if possible try changing the refresh rate of your tv
it may help.
Posted on Feb 02, 2008
Anonymous
  • 124 Answers
SOURCE: Poor picture quality from 130 degree viewing angle on my LCD tv
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Posted on Apr 10, 2008
Anonymous
  • 10515 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
Hey,
Folowing is the link for the service manual for FLU 1911 s :-
http://www.retrevo.com/s/Polaroid-FLU-1911S-TVs-review-manual/id/2894bh033/t/1-2/
I hope it wld help u :)
Posted on Nov 25, 2008
Anonymous
SOURCE: LCD TV PICTURE HAS GONE OFF BUT NOT SOUND?
when ours went the repair man went over boards on back with magnefying glass and replased 2 capacitors that had blown £20.00 he charged us
Posted on Jun 19, 2009
Anonymous
  • 8909 Answers
SOURCE: Need a manual for a
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 21, 2010
Alba LcD32880HDF. How do I reinstall free view channels.
Try here;
https://manuall.co.uk/alba-lcd19880hdf-lcd-television/
Page 19 is the stuff you'll need.
You will need an aerial plugged into the TV to receive the DTV signal in the first place.
Best of look.
Hi i have a 19 inch alba tv dvd combo in dvd mode the tv says no signal dvd is just dead tv works fine says call argos
The player has failed, it is not a product that is really repaired due to the low cost of a new one, I would just buy a stand alone player and right this off.
Alba 19" Model LCD19880HDF
Beware!!! Dracula effect behind it.
1helpful
19 Inch HD Ready Digital LCD TV/DVD Combi. Is it possible to use the USB port and if so, how?
Dear Megan,
This Port could be a Service Port or USB Input and /or USB Output. Make sure it is Not labeled "service only"
If you have a Jump Drive with pictures / music on it, plug it into the port and see what happens. This port could also be used as a charging port for cellphones,GPS etc...depending on the function it was designed for.
Good Luck!
JP
Alba 19 inch lcd user manual
I found the manual for the Alba LCD19880HDF here: http://www.tvrepairman.co.uk/manuals/alba/MB45-RC1205.pdf .
I hope this helps.
Not sure if anyone has come across this problem before. I have had 3 tv's in my son's room and all 3 different models including old one alba 19 inch lcd and another all just stopped working....
jotvguy just wondering, is there definitely power in these outlets ? Have you tried a lamp or something else to prove you have power at the wall outlet?
6helpful
3answers
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Hi, I just bought a new lcd tv and the picture is great when you look straight at it, but if you look at it from an angle it turns like a photo negative. Please help
Hi nothing you can do about that - sounds reminiscent of the old school LCD computer monitors/ laptop screens. the LCD technology has advanced significanty to170 degree viewing angles to all but eliminate this artefact.
2answers
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Top Televison & Video Experts
Marvin
Marvin
