My stove beeped and showed Error Code F7.
We were not using the stove at the time and had not used it for 2 days.
The stove is a Magic Chef Model 6498VVV Gas Range
F7
Function
key
shorted
Replace touch
padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hi Thanks for using FixYa. F1 error indicates that the
touchpad membrane is defective. To resolve this issue you’ll have to disconnect
the ribbon strip: after disconnecting if there is no fault code then the
membrane should be replaced, if the fault code still appears then the control
board should be replaced. Please do rate the solution if the issue is
resolved or post a comment for further assistance. Thanks Rylee
F1 error code description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
