Question about RTO Lawn Boy 6.75hp Mower
What is the spark plug gap setting for a LAWN BOY DURA FORCE engine 2-cycle 6.5HP?
Posted by sbrahier on
Anonymous
    New Friend:
  • 5 Answers
From what I have seen so far the gap is .30 for all manual start 2 cycle and 4 cycle and .35 for electric start
Posted on May 05, 2010
  • Dennis
    Dennis Sep 11, 2012
    I think you meant 0.030" & 0.035". (3/10" is a bit too wide) :-)
What is spark plug gap settings for a toro tb22ec trimmer
You don't have to gap the plugs on 2 cycle and 4 cycle equipment. They are already pregapped. Look at the part number of the plug and go get yourself an E3 brand plug which covers multiple plug numbers...best plugs on the market.
Sep 28, 2015 | Toro Garden
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Spark plug and gap setting
"Most" gap settings for 4 cycle engines have a .035 gap setting for spark plugs. There are a few exceptions. You can download an owners manual for most engines online with a little searching.
Apr 12, 2013 | Garden
2 cycle lawn-boy self propelled 6.5 hp Gold Pro Won't start
If you replaced the plug and still dont have any spark you probably need a new coil. If you do it yourself and find the coil on Ebay or a good onliine parts seller you could do it for a reasonable price.
Jul 14, 2010 | Garden
Where is the egine model number located on a Lawn
Go to www.lawnboy.com and input the model number of the MOWER and probably any of the serial #'s if you don't have yours. More options and info will pop up and you may get your engine model info from there. I hear that the Duraforce engines are all the same model?
Jul 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Nov 07, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
RTO Lawn Boy 6.75hp Mower Logo
4,291 people viewed this question
Top RTO Garden Experts
Dennis Key
Dennis Key
Bill Boyd
Tom Chichester
Are you a RTO Garden Expert? Answer questions, earn points and help others
