Question about Hotpoint FFA90 Bottom Freezer Refrigerator
My Hotpoint FFA90 fridge freezer has started to freeze items in the fridge compartment, even though the display constantly showed at 4deg & even when I changed fridge compartment up to 6deg (the warmest setting) it's still freezing almost everything. Can you help please? Thanks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 11, 2010
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
Sorry, but there are no adjustable vents anywhere that I can see :o(
Model is FFA90P. It has fridge at top, freezer at bottom model.
