Question about Dell Wireless 2350 Router
I tried to set up a password with my wireless 2350 broadband router and now its saying that the settings don't match my network.. i need help
  • 1 more comment
  • Anonymous Mar 11, 2010
    my computer automatically tries to connect to it but the it can't . then my computer tries to diagnose why and that's when the problem comes up. that my network settings doesn't match the routers. I did change the shared key code on the router when i went intohttp://my.router..now i cannot get onhttp://my.router to change it back
    can you clarify for me.. I looked under my wireless utility ad did not see the option to add password. under my wireless network it say right next to my router that the settings saved on this computer for the network do not match the requirements of the network. I can not find those setting anywhere.. can you instruct me please
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    where is it saying that?
Jubert Ledesma
  • 249 Answers
Change your wireless settings on your computer. Use the router's password. that way you will be able to gain access to your router. when you changed the settings on your router it does not automatically update your computer's connection settings. you have to manually change it. try right clicking the icon for your wireless on your computer. go to the connection settings and add a password that corresponds to the settings you changed on your router.
Posted on Mar 11, 2010
  • Jubert Ledesma
    Jubert Ledesma Mar 11, 2010
    what is the model of you computer? and also what is your operating system?
Idid the steps and say its connected but nothing to be trust I don,t want anybody get my internet I don,t know is th router get the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 07, 2011 | Linksys Wireless-G Broadband Router
How can i configure wireless broadband router 2.4
Hi Friend,
In order to configure the wireless settings of a router please follow the steps:
1.Open the router page (192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.On the router page click Wireless and fille the sections as mention:
Wireless network Mode-Mixed
Wireless network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID Broadcast-Enable and click Save settings.
4.Click Wireless settings and Select the security mode as WEP
WEP encryption-64 bits 10 hex digits
Key1- enter 10 digit or 10 letter password(like your telephone number) and click save settings.
5.Click Advanced Wireless Settings and fill these sections
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click save settings
Turn off the router for 30seconds and then turn it on. Your network is now secured and you can try to connect your wireless devices.
Regards
Chiranjeet
May 19, 2010 | Linksys Wireless-G Broadband Router
I don not remember my password
Are you looking for the wireless password or the
password of the router?
If you want the password of the router, then try
the default password of the router. If the default
password doesn't work then you will need to reset
the router and reconfigure the router.
If you are looking for the wireless network
password, then you will need to open the set up
page of the router. Is there any computer
connected to the router ? If not then you will
need to connect the computer to the router. Or any
other computer which is able to go online using
the router. Check the IP address on that computer.
open the set up page of the router. Set up page of
the router is the page where you will find all the
settings of the router. under the wireless section
you will find the wireless network password
Click here for more information about the routers
and wireless network.
Feb 27, 2010 | Linksys Wireless-G Broadband Router
I cant connect wirelessy with my dell wireless 2350 broadband router
Unplug router for 10 seconds and reconnect. This will stop the static charge buildup that happens frequently with routers. If needed, set up a wireless network using the network wizard and set all settings to automatic.
Sep 22, 2009 | Dell Wireless 2350 Router
I have two Dell 2350 Wireless Routers trying to bridge or repeat
The first router must the root AP and the second should be set to Wireless Repeater. Follow the steps on how to resolve this setup.
1. Get the Wireless MAC Address of the main router. The router has two MAC addresses, one is wired and 1 is wireless. To determine the wireless MAC address, go to Status page of the router, there's a sub tab there for wireless and you'll see the Wireless MAC Address. Take note of it.
2. Access the setup page of the 2nd router. Change the LAN IP address to 192.168.0.2 then save. Power cycle it by just turning it off for 10 seconds then turn it back on. You can now change it to Wireless Repeater and there's an option for you to type the Wireless MAC address of the main AP. Make sure all wireless settings are the same on both routers like SSID, Channel and Encryption Key. Save your changes after that.
3. From your computer, try to ping the 2nd AP which is 192.168.0.2. If it replied back, you're all set.
Good Luck!
Jul 25, 2009 | Computers & Internet
My friend ave me a dell 2350 wirless router without the software. i dowbloaded the software and it asks me to put in eser name and password. it's saying its the wrong name and password
http://support.dell.com/support/edocs/network/2350/en/CONFIG/settings.htm
Undoubtedly, it's asking for the administrator information. User name is admin and password is admin. The link will show you the default settings for the router should you have to reset it.
Thanks for using Fixya.com . If you liked my answer, please rate it accordingly!
Jan 11, 2009 | Dell Wireless 2350 Router
Forgot username/password for Dell Wireless 2350 Broadband Router.
Do you mean you have forgotten the wireless password for your network?
If so , there is are several tools available online which recover the wireless key as long as you have previously connected to that network from your computer.
Try http://www.nirsoft.net/utils/wireless_key.html
Dec 29, 2008 | Dell Wireless 2350 Router
Disconnection problems
I see. You can try changing the wireless settings of the router. You can do that by accessing the web based utility of the router. Here are the instructions:
1. Click the Start button, and then click Run.
2. Type the following text in the Open box: http://my.router
3. If this is the first time configuring your Dell Wireless 2350 Broadband Router, or if the user name and password have not been changed from the default settings, type admin in the User Name field and admin in the Password field.
4. Click the OK button. The Configuration screen appears.
5. Under the Basic settings, under Wireless Settings change the channel from Auto to 1, 6, or 11.
If that does not work, you can try updating the firmware of the router. You can download the firmware from this site:
http://www.dell-drivers.com/dell-drivers-downloads/Dell-Wireless-2350-Broadband-Router_8689.shtml
Here are the instructions on how to upgrade:
1. Reaccess the configuration page of the router using a wired computer.
2. Click on System Tools, find Firmware Upgrade.
3. Click Browse and search for the firmware you downloaded from the site I gave you earlier. Select it and then start the upgrade. Let the firmware finish its upgrade.
May 21, 2008 | Dell Wireless 2350 Router
Wireless security
Hi
Here is good guide to setting up security
on Your Dell Wireless 2350 Broadband Router
http://support.dell.com/support/edocs/network/2350/en/ex_confg/set_sec.htm
Mike
May 14, 2008 | Dell Wireless 2350 Router
Dell Wireless 2350 Router Logo
137 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
