Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Posted by rebeccagerma on
Dave Smith
    Scholar:
  • 86 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Posted on Mar 11, 2010
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Electrolux washer -dryer water not going into machine
Firstly we will need some more info. Does anything happen when you press start? Can you do a drain only? A spin only? Any countdowns, display info or flashing lights? Have you got hot and cold water connections and have you tried both settings?
If when you start the washer and everything is in place for your washer to fill and no water enters then it is the solenoid valve (water inlet valve) On a front load washer remove the top cover and you will see it clearly at the rear. They are fairly cheap, also check that the filters in the hose connection of the valve are clear.
Feb 05, 2014 | Electrolux Washing Machines
Hotpoint washer displaying F-01
take all the clothes out and pail the water out....turn if off at the wall socket and then set to start.this MAY work.
Jul 21, 2010 | Hotpoint Aquarius WD640 Front Load...
Kenmore Elite Calypso Washer fills then doesn't advance..
You can get a replacement pump at pcappliancerepair.com - part # 285990 - and a lifetime replacement warranty on the pump - for (at this time, July 2009) about $124 total.
However, before you do anything you can run the washer diagnostics by pressing the following key sequence to put the washer into the Automatic Service Diagnostic mode (make sure the washer is EMPTY of clothing when you do this):
Prewash Options --> Wash time --> Prewash Options --> Wash Time (also known as a "Key Dance"). You have to press the 4 keys within 5 seconds for the washer to enter the diagnostic mode.
The washer will start counting down from 99 on the LED display and will run through the following steps:
Display 99-81, Nutate & Fill (washer plate rocking motion is called Nutate), Cold Water, Drive Motor Speed 300
Display 80-61, Nutate & Recirculate, Cold Water, Fabric Softener Dispenser, Pump in Recirculate mode (wash), Drive Motor Speed 275
Display 60-41, Nutate, Fill & Drain, Hot and Cold water, Bleach Dispenser, Pump in Drain Mode - LISTEN FOR IT TO RUN, Drive Motor Speed 250
Display 40-21, Nutate, Fill & Drain, Hot Water, Detergent Dispenser, Pump in Drain Mode, Drive Motor Speed 225
Display 20-01, Spin & Drain, no water fill, no dispenser solenoids, Pump in Drain Mode, Drive Motor Spin Speed 500
Return to Standby at the end of the countdown.
You can press Cancel at any time.
Also, if you can get the washer drained, when you tip it on its side and open the bottom cover (unplug the AC power first and secure the water lines & drain), if you shine a bright flashlight up inside the outer case of the washer, look for a plastic sleeve with some paperwork in it.
If it is there, you will find the washer's Service Diagnostic Paperwork, a large fold-out sheet that shows all the keystrokes, like those documented above, for putting the washer through a bunch of diagnostics.
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
INTERMITANT FAULT
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Jul 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Display lights
make sure there water going to machine, remove fill hose to see check inlet filters.good luck eire
Dec 07, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
No draining of water
poss blocked hose or debris in pump.
May 29, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
330 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
