Ovens Logo
Question about Ovens
Water is pouring out of the bottom of Rational oven SCC 101 E
We can't figure out why water is pouring out of the bottom of the oven? Also happens when the oven is off - water continues to drain.
Posted by sschmidt94 on
Anonymous
    New Friend:
Theres a chance you have a deffective solenoid staying open causing the water to overfill the boiler tank and passing out the overflow into the quench box and down the drain!
Posted on Dec 21, 2010
Phillipe Lys
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
More than likely the drain hose has worn and split, open the side panel and it is the white pipe that runs from the drain pump to the top of the tank
Posted on Jul 12, 2017
Jorge Casillas
    Habit-Forming:
    New Friend:
  • 8 Answers
Bad solenoid
Posted on Nov 11, 2015
2helpful
Rational SCC 202 service 34-6
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
Jul 09, 2013 • Ovens
2answers
Scc-101 rational fault codes
Rational SCC error code service 100
Aug 27, 2012 • Ovens
13helpful
4answers
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 • Ovens
Top Ovens Experts
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
