Acme 6001 Juice Extractor Logo
Question about Acme 6001 Juice Extractor
My juicerator will not run with the stainless steel juice bowl attached. It seems to rub to a halt.
Posted by mquion on
  • Alex Hoyt
    Alex Hoyt Aug 26, 2014
    Was this issue solved? I have the exact same problem with mine. The steel bowl is putting too much pressure on the juicing blade causing the motor and blade unable to spin.
Anonymous
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
1helpful
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Will not run
mine either, went to juice and the motor was running but not strong, then it just quick working...would love a solution as i love my juices! your help would be appreciated
3helpful
For an Oster Juicer Model 3165, how do I remove the stainless steel basket? Thanks.
Move from side to side and jiggle the whole assembly .. including the juice collector and juicing basket. With patience and even a break between attempts it will finally dislodge itself and lift up and off.
Just juiced carrots and a couple apples .. mmmm good ;-) best of luck
Broken bracket
Hi, I have the Acme 6001 Juicer and I love it! I would take the broken bracket and the juicer to a machine shop that does welding. Shouldn't cost more than a few bucks for them to spot weld the bracket back on. A good maching shop can fix this as they will have another bracket to reference the repair. hope this helps...gary One of our local shops can fix about anything and they are very reasonable and pretty quick.
Jack la lanne juicer
Heres where you can buy a new one:
https://www.unitycart.com/pjss/accessories/parts_classic.asp
2answers
Stoop running
very easy to take apart. since all the skin and hard parts of fuits and veg. are shredded theybtend to stick and bunch up in the machine, sumtimes against blades.clean after every use inside and out
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Open Questions:
See all Acme 6001 Juice Extractor Questions
Top Acme Juicers Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you an Acme Juicer Expert? Answer questions, earn points and help others
