I have two hifonics hfi 12d4 and they hit but not as hard as when i first put them in and i didnt over power them there rms is 300 and my kicker zx250.2 has a max output of 300w and when they hit they whisper. and they have that ozone smell like its burning? any fix or are they trashed?
whats causing it to be blown though? the web is fine there arent any craks? is it fixable?whats causing it to be blown though? the web is fine there arent any craks? is it fixable?
You can't post conmments that contain an email address.
Signal getting to and from the Amp is problematic, if you do not have the correct wiring that will carry the necessary power then you are never going to get the sound you are looking for. Start with testing the AMP and then Wires....
Ok, your post has two different models listed. Let's start with something you need to know about your amplifier. Is it one ohm or two ohm stable. This will make a difference. Also, whether your subs are single voicecoil (HFI12s4) or dual voice coil (HDI12d4).
Let's start with the easy scenario. Let's say your amp is two ohm stable and you have two single voice coil subs. It's simple. You go from the positive of the amp to the positive of both subs and the negative of the amp to the negative of both subs. This will provide a 2 ohm load to the amplifier, thus pulling all the power out of it.
Unfortunatley, if you have two dual voice coil subs, you won't be as efficient. You will only have the options of a 4 ohm load or a 1 ohm load.
This is where having a one ohm stable amp would come in handy. If the amp is one ohm stable, hook the positive of the amp to all 4 of the positives on the subs, and hook the negative of the amp to all 4 negatives of the subs. This produces a 1 ohm load.
WARNING!! If you have a 2 ohm stable amp DO NOT use the last wiring scenario. It will fry your amp.
Now, the last is a little trickier. This is for two dual 4 ohm subs. Follow closely. Hook the positive of the amp to one of the positives of each sub. (do the next step to both subs) Go from the negative of the voice coil that you hooked positive from the amp is hooked to, and hook that to the positive of the unused voice coil. Then go from the negative of that voice coil and hook to the negative of the amp. Make sure this is done on both subs. This will give you a 4 ohm load.
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
Check power supply diods. power supply capacitors and power supply and output transistors.
Remember, distortion is the biggest killer of subs and amps. Everything made by anybody has its limit.
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
