Question about DISH Network IR Remote Control
My dish network remote stop working
I using remote 2 for bedroom. i pressed the power button on the remote. when i came back i tried to turn it back on but the tv wasnt responding . the ligh in the remote still glow whern i pressed the button but i dont think it reached the DVR. i need help i dont know what happen.
Posted by djoseph140 on
Anonymous
    Scholar:
    New Friend:
  • 24 Answers
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Posted on Feb 10, 2011
Need remote codes for dish network
Hello!!!! Here are some codes and the process of programming your remote to the tv. It is very quick and simple!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
578
580
564
Becki Barned
DISH Network Customer Service
Jan 28, 2011 | Olevia LT32HVE 32 in. LCD Television
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
Sep 16, 2010 | DISH Network IR Remote Control
TV IS AN ORION TV/VCR COMBO. THE BEDROOM TV IS IN RUNS OFF THE LIVING ROOM RECEIVER. THE TV CHANNEL IS SUPPOSED TO BE ON 60. NO REMOTE 4 TV, TO CHANGE CHANNEL TO 60. TRYING TO PROGRAM DISH REMOTE. 1 CODE 4...
zassyway
I have provided instructions on how to program the remote to your TV. I have also provided codes for your TV brand.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The codes are as follow: 720, 220, 748, 721 (694 only has a 2% success rate). I hope this helps.
Ray Calo
DISH Network
Jun 18, 2010 | DISH Network IR Remote Control
Dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Jun 02, 2010 | DISH Network IR Remote Control
I HAVE A OLD TV WITH VCR SHARP Y NEED THE CODES NUMBER FOR MY REMOTE CONTROL 3.2 IR
try using a power scan:
    1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
    2. We do have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
    2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
    3. Press and release the Power button.
    4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    6. To verify the code works have the customer try several different functions for that equipment.
    Oct 24, 2009 | DISH Network Televison & Video
    Dish network remote code for Disney 13" TV
    On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
    Dec 31, 2008 | Disney 13" TV
    Dish network remote
    i would suggest trying power scan again...
    1)hold down tv button next to sat button in top left corner
    2) when all buttons illuminate press 500 into remote
    3)press pound sign
    4)Hello, please help..
    5)hold town tv button again.
    6)when all buttons illuminate press big red power button
    7)press up arrow once a second until tv shuts off
    8)press # pound sign
    9)try to turn tv back on w/ big red power button
    10)if tv doesnt turn back on try again from step 2 but use down arrow instead
    if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
    Jul 06, 2008 | DISH Network IR Remote Control
    Echostar IR remote (Dish)
    to set remote to tv
    3)press pound sign
    to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
    Apr 30, 2008 | DISH Network IR Remote Control
    Dish network
    Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
    Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
    If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
    3)press pound sign
    To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
    Dec 11, 2007 | DISH Network IR Remote Control
    Dish Remote
    I was given code numbers for the Olevia TV, 506 and 127....... they dont work for my 32" in my bedroom.
    Nov 16, 2007 | Televison & Video
    DISH Network IR Remote Control Logo
    253 people viewed this question
    Top DISH Network Televison & Video Experts
    matt martin
    matt martin
    Sheldon Dedek
    Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
