Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer is giving a code of "F2" & not draining properly.. any idea?
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2236410
Points
18738
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Whirlpool F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
2helpful
F2 Code???
Probably blockage in pump or sump
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Hello Im getting a code F2 what do Im using Ultra HE detergent. One time I added chlorine straight in the washer, bad idea and noticed since then it continues to show the code F2 often on with some...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
I am getting an F2 error constantly on every wash. Any ideas what this F2 code means or how I can fix it. Thanks
1 check the drain hose to make sure its not kinked.
2 unplug the machine
3 check the electrical plug at the pump and make sure that the pump runs
4 check the drain pump filter for foreign objects
5 plug washer back in
6 if the above does not fix the problem go to #7
7 unplug machine
8 Replace the pump
Part #8181684 http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-11042922200/0583/0153200/P0309046/00006?blt=06&prst=&shdMod=
2answers
My kenmore washer model 4586 or 4587 gives me a reading of F2...according to the manual, it is not draining properly....how do I remove the drain hose to make sure there is no blockage?
If it is like mine you remove the 3 screws from the very bottom. The cover will come off. I just had this same problem. In the center bottom there is a white cover that unscrews. Beware you may have a bunch of water come out. In there is a screen. I found a couple baby socks stuck in there. Look up the tube from the drum as well. Good luck.
I have a Whirlpool Duet. Recently I had an F2 signal and an interrupted spin/drain cycle. I removed the pump, cleaned out both the internal and external drain hose (which were full of grey/black goop). I...
You washer might have all kind of problems. You need to check all the below :-
Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Are you using HE rated detergent? You MUST use HE (high efficiency) rated detergent in this washer. Your washer uses less water than traditional machines. With less water, the wash action can create too much sudsing when regular detergent is used. The lack of HE use will also cause the machine to use a greater amount of water and cause your error code F09.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
