Question about Bernina Sewing Machines
Bobbin jaming up - Bernina Sewing Machines
Posted by jjetheringto on
paj42
    Genius:
  • 1,116 Answers
Clean the bobbin area.
Thread the machine with the presser foot up - always,
Make sure the bobbin thread is feeding clockwise and through the guides on the bobbin case.
Lower the threaded needle down and back up while holding onto the thread end. This will pull the bobbin thread up. Hold onto both threads and pull under the presser foot and to the back of the sewing machine.
Hold on to the thread ends and lower the needle into the fabric, then press the foot pedal.
You may want to use a leader - a folded scrap of fabric that you sew to the edge of and then **** against the fabric you want to sew. Sew off the leader and onto the fabric and this will keep the thread from going down into the machine. You can have a few stitches between the two to make it easy to cut the leader away.
When you stop to adjust the fabric make sure the needle is down to anchor the fabric (turning corners, sewing a curve. etc).
The slightest movement of the fabric when the needle is up will sometimes cause a thread jam.
Posted on Mar 11, 2010
My machine James now the bobbin keeps falling out
Check the manual to make sure you are putting it in right and also
entire bobbin case that the bobbin fits in might not be in right.
Jan 30, 2015 | Sewing Machines
Why is my machine jamed
Sounds like a thread jam ! Open bobbin case housing remove bobbin and clean away thread ! Do not force the balance wheel to turn or you will knock out the timing !
Aug 25, 2014 | Tacsew 20U43 Sewing Machine
How to fit the bobbin holder called the shuttle into the machine correctly
Lean the machine at an angle so it will not fall out...Hook will only fit one way, then ring with "bull horns" that go to the top rear, then lugs hold it on then insert bobbin case
Mar 10, 2014 | Janome Sewing Machines
The machine jams
make sure the top thread isn't coming off the thread take up lever and also the sewing machine may need to be checked for a timing problem.
Aug 08, 2013 | Bernina Bernette Deco 600
The thred keeps jaming in the bobben on my 9110
Check to be sure your bobbin is in correctly. so turn clockwise, others counterclockwise.
Jan 07, 2013 | Euro-Pro Shark 9110 Sewing Machine
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
The bobbin keeps getting jamed
rethread the machine top & bobbin
make sure the bobbin is not fully wound, usually wind the bobbin
3/4 full, when I was sewing last night & rewound the bobbin & I wound
it to full & it jammed twice on me.
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area
Aug 08, 2012 | Singer Pixie Plus Sewing Machine
Getting the Bobbin threaded in the Machine
when this has happened to me, the upper thread has somehow run amuck. check to make sure the top thread is STILL routed properly. It might have nothing to do with the bobbin.
Sep 05, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
188 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
