Good day!!
Example Situation:
If you can get the first thirteen channels, then that
proves there are no broken wires or damaged equipment
between PVN and your room. Your cable - all 67 channels
- has already been activated before you even move
into your room. So, if you are only getting channels
2-13, you definitely have a programming problem with
your television.
We understand that your TV probably worked great last
year or at home, but you have to set it up from square
one when you move in to Penn again. Many times when
you unplug a cable-ready TV, the memory settings are
lost, and you have to start over. Therefore, you will
need to
program your set from the beginning.
If that situation happened to your TV please re-program your set.
Here is a link on how to re-program your Set.Just click the link bellow:
http://www.upenn.edu/video/setup/tsfaq.html#2-13I hope your problem could be solve by this solution.Just add a comment for more query.Thank you!!
