I have a garmin nuvi 250 that being charged. some one hit the back of it causing the port to come loose, it no longer charges. ive had it for 3 years, so would it posible to open it and try to realine the port?
Charging via a PC is not the quickest way to charge a GPS because many USB ports can not supply enough current, so the battery will take longer to charge. Using an AC adapter is a better way. Leaving the unit to charge over night should be fine. The way to tell if the GPS is fully charged is to look at the battery icon on the main screen of the GPS. It consists of 4 bars. 4 bars = fully charged. 3 bars = 75%, 2 bars = 50% and 1 bar = 25%.
Most issues causing this is a bad charger, dead battery or caused by a loose USB port in the back. If the port is loose, the battery will not be charged and won't even work when connected to an external charger. More info can be found here:
Just connect the satnav to your computer with the mini USB lead. The narrow end goes in the back of the satnav and the other end in the USB port of your computer. You need to have the computer turned on and if the satnav doesn't turn on automatically turn it on also. It will take approximately 8 hours to charge.
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
This is the problem with the Nuvi 2xx series... the charging port connector on the rear is weak and eventually the connections fail. It does not have a quick disconnect port like the Nuvi 3xx, 6xx or 7xx series.
The connector has to be either resoldered or replaced. The bad connections are whats causing the problem, making your Nuvi think its connected to a PC rather than a true charging power source.
I called Garmin re this question. They said about 4 hrs in the car, about 6-8 on the computer. I left mine plugged to the USB port overnight and have a full charge. BTW Radioshack sells an AC adapter for about 30 bucks. If if also works for the latest iPod I think I will go with it. 4hrs.. says Garmin
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMINNUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugtheusb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
