Sharp AR-M237 Copier Logo
Posted on Mar 10, 2010
Code u9-80 the copier displays, "code u9-80, call assistance."
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
22207
Points
21
This indicates a communication failure between the Main Control Unit and the operation control circuit board. Power the machine down and disconnect from hte power supply. Check all the connectors and wiring on the boards and also any loose wiring that may be grounding the machine. Power back up and if the fault persists a qualified copier engineer will be required.
We, 07 rendezvous park aid quit working. Needfixed
Rear Parking Assist Inoperative - Red Indicator Flashes
Does the red indicator flash ?
Diagnostic Aids
• The RPA system is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes from the RPA display. Before using this diagnostics, it is necessary to get familiar and understand how the on-board diagnostic feature operates. Refer to Diagnostic Trouble Code (DTC) Displaying and to Diagnostic Trouble Code (DTC) Clearing on how the diagnostic trouble codes are displayed and cleared from the RPA display system.
• Make sure the rear park assist (RPA) object sensors located on the vehicle rear bumper are clean and clear. Remove any objects that is blocking the sensors.
• Inspect for after market devices which could affect the operation of the RPA system.
This vehicle is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes using the 3 indicators on the rear parking assist display. After the bulb check has been completed, the red outside indicator flashes to indicate a malfunction with the system. The module disables operation of the URPA system under this condition.
In order to enter the diagnostic mode, complete the following actions:
With the ignition turned OFF, short the rear parking assist diagnostic connector to ground while the vehicle is in PARK. For the location of the rear parking assist (RPA) diagnostic connector, refer to Object Detection Component Views .
Turn ON the ignition.
Place foot on the brake.
Shift the vehicle into REVERSE within 5 seconds.
If the vehicle is not shifted into reverse within 5 seconds after turning the ignition ON, the diagnostic mode will still be initiated. However, a reverse input wiring fault will be registered as sequence #7 as shown in the Diagnostic Indicator table below. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes. After the reverse input wiring code is cleared, repeat the diagnostic trouble code displaying steps in order to enter the diagnostic mode.
When the diagnostic mode is first entered, the rear parking assist display displays the amber outside indicator and the red outside indicator. Then, the indicators on the rear parking assist display will display one or more of the sequences in the table below to indicate where the fault exists within the rear parking assist system. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes.
The Rear Parking Assist (RPA) Diagnostic Connector (UD7) is under the front of the center console behind the BCM - body control module.
Xerox 3030 (engineering copier)-- "Toner Fault. Call for assistance" is on the little display screen. Can I easily fix this myself?
I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
3helpful
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
1helpful
Error h200
H2 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
1helpful
Error code f35-6 on konica 7145 copier
Replace Thermo- fuse (open ) fuser not getting to 160, and clean thermister, toner builds up between roller and thermister causing overheating of fuse to blow .
3answers
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
3helpful
3answers
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
