Question about Kenmore 47732 / 47734 / 47739 Electric Double Oven
We are getting the code f7 on model 911.47642100 .should the electronic range control be replaced? john hodges
5 Suggested Answers
6ya staff
SOURCE:
Powerman
Charlie Popeck
  • 68 Answers
SOURCE: kenmore 911-9359181 serial 1r260309r
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have now shared this with over 1450 folks and most report success. I hope that it works for you too. You can also find my solution at my website:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if it works for you at [email protected]
I am making a study of this problem. What is your model number and how old is your oven.
Posted on Nov 28, 2007
Mark Egan
  • 1214 Answers
SOURCE: flashes code F3 (sometimes f5) and beeps
OK. I found the manual your looking at. The serial number label is located at the back left and underneath the cook-top. I am not certain if you can see it by removing the burner and tray, but if not, you can "pop the top" by grasping along the seam at the front of the unit, just above the door. DISCONNECT POWER FIRST!
And, in doing some more looking around, if you have reset the controller using the instructions from the manual (which includes disconnecting power for about an hour), then odds are pretty high it's either the temperature sensor, or the controller. The sensor is cheap, the controller more expensive, but odds are better it's the controller. Replace, or have, both replaced. You'll have essentially a new oven when you do this.
Posted on Jan 15, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: kenmore model 911 4238816 - the f7 code just came
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jan 04, 2010
Ishola Olayemi
  • 1196 Answers
SOURCE: I installed a new control
F7 on kenmore range, this usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition, the control panel you just fixed might not be working one, because if it is, it is suppose to fix the problem,. F7 on kenmore oven range means the control keypad is faulty and must be replaced.
Posted on Jun 13, 2011
F7 error code
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Ovens
Alarm comes on and display shows f7 code
Kevin
Apr 11, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
Fault Code "F7"
Kevin
Mar 07, 2011 | Maytag CWE5800A Electric Double Oven
I have a GE Range model JBP85. I have an error code F7. It appears the clock key is stuck. Is there any way to unstick this or any other key? The key pad is expensive to replace.
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Oct 23, 2010 | GE JTP15 Electric Single Oven
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
F7 CODE
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
F9 Program w/ door circuit Check wiring
Mar 21, 2010 | GE Built-In 24" Double Electric Wall Oven
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
Open Questions:
Kenmore 47732 / 47734 / 47739 Electric Double Oven Logo
145 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
