Question about Krups Blenders
How can I open akrups gpa3 blender.It does not work only 3 years
I just need to open a hand blender of krups model gpa3 .I don´t want to break it.
I don´t have a near service shop, and sending it to the official service costs me more than the price of it.
It does not turn at all. may be I cat repair it myself
Thank you
    New Friend:
The body of the blender is held together by three cross head screws two at the base which are clearly visable and a third which is concealed by the pulse on/off switch which you need to prise off to reveal - small spring to rear to catch! Our blender went totally dead due to a blown internal fuse which I have now replaced and hey presto we are back in action.
Posted on Feb 08, 2011
    New Friend:
Its a bit hard to remove it, but eventually it will come off.
Mine is a Krups GPA1 and the on/power button has two hard clips (each one with a large spring easy to work with) that need to be pulled out of their sockets.
How can I open akrups gpa3 blender.It does not wor - 9_26_2011_4_16_59_pm.jpg
Posted on Sep 26, 2011
  • Tiago Capristano
    Tiago Capristano Apr 04, 2013
    Sorry, wrong blender! ;)
    New Friend:
Just to let you know that 6 years later your post is still helpful ! We are from France and could not find ANY info on how to dismantle this thing.
Thanks ;)
Posted on Jul 17, 2016
6ya staff
SOURCE:
What year was the Krups 243 Blender manufactured?
Sorry we do not have that kind of info here at this website.
May 10, 2018 | Krups Blenders
O RING 574
There are 4 Krups 574 models, the seal shows as obsolete for 2x of them and still current for the other 2x
Part number for the seal that is current is MS 0974091
Apr 19, 2014 | Krups 574 Power Xtreme VI Premium Work Top...
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
Aug 12, 2011 | Krups 572 Power Xtreme VI Work Top Blender
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
Need owners manual
I didn´t find it with google. Maybe ask the experts from manualfox.com - if they don´t find it, it does not exist.
May 12, 2009 | Oster 6812 / 6813 / 6814 16 Speed Blender
Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Apr 08, 2009 | Krups 239 Power X Plus Work Top Blender
Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Nov 04, 2008 | Krups 239 Power X Plus Work Top Blender
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Blenders Logo
1,245 people viewed this question
Top Krups Blenders Experts
Ross Keen
Marvin
Marvin
Jeff Bird
Are you a Krups Blender Expert? Answer questions, earn points and help others
