Question about Sony Handycam DCR-SR42 Camcorder
Hi, I have a sony handycam dcr-sr32 camcorder fault code E61:10
Hi, I have a sony handycam dcr-sr32 camcorder which is flashing fault code E61:10, I have tried the bash and drop method suggested on other sites but sadly this hasn't worked. can you help please with any more suggestions. many thanks Phil
  • 1 more comment
  • Anonymous Mar 10, 2010
    Thank you omtronixom for you fast reply have you any advice on how to repair the fualt or will it be a new motor (back to sony)? Many thanks
    Phil
    Phil
    Many thanks for your help. I will do that.
    A good, quick response.
    Take care
    phil
om sharma
  • 172 Answers
Either focus motor or zoom motor not working so that error code E61:10 fashing
Posted on Mar 10, 2010
  • om sharma
    om sharma Mar 10, 2010
    Best contact Sony Service Centre
Sony Handycam DCR-SR32
At the nearest SONY service centre
Apr 19, 2014 | Sony Handycam DCR-SR42 Camcorder
I have lost the software to download my vodeo from my Sony DCR-SR32 any ideas where I can get a replacement or download?
Here is the main support page for your camera:
Sony DCR-SR32E Support
The download links are listed.
Thanks for using Fixya. Please take a moment to rate this solution. Thank you.
Apr 26, 2010 | Sony Handycam DCR-SR42 Camcorder
Sony DCR-SR32 lost docking station is there a usb lead that will connect camera to my pc
http://pinouts.ru/Home/sony_dcra_pinout.shtml here is the pinout from the camera.if u cand handle it work but u need some exprerience to do this.to buy some cable ...i think nope
Sep 28, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a grey screen - what can I do?
Mi had problems colours on the beggining the finaly stopped DCR-SR32.
I changed by miself (it's cheaper not very easy) flex wire that conneting LCD with camcorder and it's like new. it's very common problem with DCR-SR. You might try to get the wire in the repair shop like I did it.Good luck
Meggita
Sep 17, 2009 | Sony Handycam DCR-SR82 Camcorder
The lcd screen is not showing anything but the touch screen works on it
I got DCR-SR32 had the same prblem. Changed the flex wire connecting LCd with camcorder and it's like new.flex wire got from repair shop was 1-871-457-11 check yours I did it by miself it's cheaper. Good luck
Meggita
Aug 31, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
No picture, just a blank screen, Controls do not work except the power switch from video to picture.
does the panel function beeping? if so change the flex wire that conneting LCd with camcorder 1-871-457-11 in DCR-SR32 and many others. I bought it in repair shop and did by miself it's cheaper.
Hope it helped
Meggita
Aug 20, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
MY SONY DCR-SR190 HDD CAMCORDER LCD SCREEN KEEPS CUTTING OUT, IT
mine started like yours then stopped working at all .It's a flex wire that connecting LCD with camcorder. it's very common. I did by miself, bought it in repair shop. works like new. mine is DCR-SR32 wire is 1-871-457-11 known as 1-871-457-21
good luck.
Meggita
Aug 16, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
Error code C:31:42 on a Sony Digital Handycam DCR-TRV530
Here is the solution to your problem:  C:31:42 = FG (film guide) fault during normal drum operations. Load the tape again, and perform operations from the beginning! Hope this helps.
Fotobean
Jan 19, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony Handycam  DCR-SR42 Camcorder Logo
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
