Question about Ricoh Aficio SP C820DN Laser Printer
Replaced a hp 8150 with a ricoh 8200. When
Replaced a hp 8150 with a ricoh 8200. When duplexing, ricoh starts on back side of paper rather than front. So when using 3 hole punch paper, punched side on a duplexed page is opposite side of a nonduplexed page.
  • Anonymous Mar 10, 2010
    If I turned the paper stack over, the pages that do not duplex would still be opposite of the duplex pages
    I will see if I can get those print files for you. It is a laser printer using postscript. We are actually printing statements for customers in segments. Within the segment there will be some statements that are not large enough to be duplexed and they are correct. The statements that do need to be duplexed are the ones that are incorrect. Specifically the pages that are duplexed.
Don Farrell
    Genius:
  • 1,018 Answers
That is the way duplexing works. Both sides of the page are read into memory and then the second page prints followed by the first page after the paper turns around.
Turn you paper stack over so the the 2nd. page prints correctly on the page and the first page should be fine. If it does not, please let me know and we can take some steps to look at the data going to the printer.
Don
Posted on Mar 10, 2010
  • Don  Farrell
    Don Farrell Mar 10, 2010
    I'm sorry, I thought you were only doing duplexed jobs. My error.
    Okay, let's start again. When running single-sided print jobs, the image is correctly placed on the page, correct? It's only when you switch to duplex mode, that you get the failure, correct?
    Is this printer a laser printer using either a PostScript emulation or one of the several PCL emulators? If it is an inkjet, I will tell you up front that I cannot bust into the datastream and figure out the bit patterns.
    Can you please capture a Print-to-File of a failing print job and a working print job. You capture the print jobs, by using the Print menu and setting the check box for "Print-To-File". When asked to name the file, name the failing job as "failing duplex" and the operating system will put a ".prn" extension on the file. Do not use the quotation marks.
    Send both files to me at [email protected] and I see if I can fix them and in the process tell you what is going on.
    Don
How do i remove the paper from the duplex unit when there is no paper there
You could have a broken actuator or the spring came of. I would check all areas for paper not only the duplex area. I've seen paper jams in other areas show a different indication on the display.
Sep 21, 2014 | RICOH - PRINTERS Ricoh Aficio Sp C430dn -...
I would like to copy a 2 sised doucment as a 2 sided document
Not sure that model has duplexing - according to this site http://www.digitalsystemcopiers.com/Ricoh_Aficio_1013Fspecs.html duplexing is an upgrade.
here is the link http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio1013f.pdf to the manual
If a duplexing unit was added, you will have to refer to those instructions, if not then you will have to copy it one side at a time feeding the paper manually and flipping it manually.
Apr 08, 2014 | Ricoh Aficio 1013F Copier
HP LaserJet 4000 Duplexer
I realize when I say this that you will be a little skeptical but I will say it anyway . the Paper may be damp - do you notice any curling from your print if only printed on one side? this is the easiest way to test for damp paper- while the paper is damp the Electrical resistance is much higher than when its dry and this is what typically gives a Light copy however once the paper has been though the Very Hot fuser rollers to \'fix\' the first side, the paper has been force ably dried and so the second side is much Stronger in toner. try a new ream of paper and see if that helps
Jan 22, 2014 | HP LaserJet 4000 Printer
Can you add duplex double sided option to HP d1660
No duplex option is available. The only way to duplex is manual. Meaning you have to print the first side, then turn the page over and re-insert into the printer. Then print the 2nd page onto the back of the first page. The reason this is not an option and generally you do not want to duplex on these machines is that the ink will tend to bleed thru the paper when prining on both sides of a piece of paper. You may have to use a little thincker paper to prevent this.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | HP D1660 InkJet Printer
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
May 13, 2010 | HP LaserJet 4650 Color Printer Manual...
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Paper Jam from the duplex into the Main Unit
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Dec 11, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 2035G Duplex issue
When you open the whole duplex unit you will see a very small metal tab with a screw, on the top right side on the machine. This activates the switch on the duplex unit.
Or with the duplex unit open you will se a small rectangle hole inside a switch, put a piece of paper or something to activate it, might got stuck.
This problem is very common on this machines.
Nov 18, 2008 | Ricoh Aficio 450 Copier
HP LASERJET 4250 DUPLEX ISSUE
only problem ive had with the earlier model not doing duplex was a sheet of paper in the duplexer bin . This is hard to find but if you pull out the paper tray and look in the space where the tray goes up above theres a lever which you can push and it releases the hidden duplex bin which stores the paper at half way through the double pass and if there is any paper in there then the printer will not duplex.
Oct 02, 2008 | HP LaserJet 4250n Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Ricoh Aficio SP C820DN Laser Printer Logo
284 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
