SOURCE: siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
SOURCE: I have a computer, a all-in-one printer, a phone
Okay... Let's see if I can help you out.
Yes, your cable modem should have a phone jack on it. Are you sure it's a modem and not a router? Do you have phone service through your cable company? If so, your modem should be phone ready. Just checking..... :-)
The first thing you want to do is get your computer completely set up and ready to run (do not turn on yet). Just make sure all components are plugged in. Everything should be color coded and different sizes & shapes making it virtually impossible to cross anything accidentally. Your mouse and keyboard should be the only two components having the same kind of connection but they are color coded on the connectors and behind the computer too. No worries!!! :-)
Next, get your modem hooked up. Plug in power cord and attach cable wire into the back of the modem. Next you'll need an Ethernet wire to go from the back of your modem to your computer. If you're not familliar with ethernet - it looks like a phone cord only bigger.
Next get your printer wires hooked up to your computer as per directions for your specific unit. Should be fairly simple.
Once you have everything connected, power up your modem. Once it's finished booting up, turn on your computer. Once your computer is completely finished booting up, Turn on your all-in-one. Your computer should now be showing...Found New Hardware. Follow on screen prompts.
I hope this info was helpful to you. If you do need further assistance don't hesitate to ask. If needed, I'll give you my # so I can walk you through it over the phone.
Good Luck!
Contact Magic Jack product support for this, we do not have any info on this problem here at Fixya.
