Question about Electric Currie EZIP 500 Scooter
On my kaos electric scotter i can,t tell how much battery life i have left or when i need to charge it the battery gauge just stopped working can it be a loose wire someware if yes where would i look
Posted by shawnsulliva on
Herbert Norris
    New Friend:
    Problem Solver:
Is there a device that tells you how much charge is left in your
battery -can you tell me the name of it i believe Maplins sell them i want it for my Mobility Scooter
Posted on Mar 05, 2011
If you can please tell me how I can tell when I need to charge the battery. I also need to know the amount of time to that I should continue to charge it. Can over charging hurt the battery???
The Tablet should have a Icon, showing you Battery Life , (ie) how much you have left in battery . You can't over charge battery , as computer has safty cut off,
Mar 15, 2015 | Tablets & eReaders
Van runs fine then radio,lights, gauges,windows,blinkers and everything else thats electric stops working.jumped the van and everything works fine for about 20 to 30 mins. then it does the same thing again
This sounds like an alternator problem. have the battery and charging system tested. this test will tell you if the battery is good and also if the alternator is good.
Mar 03, 2013 | 2000 Ford Windstar
Turn on key shows full charge.but within 30secs one green goes out and one red starts flashing invacare scotter
those lights go by voltage not amps the battery has charge the battery then remove it bring it to a auto parts store to have it tested
Mar 31, 2012 | Electric Mobility Invacare Pronto M41...
I purchased a Ryobi drill with Lithium batteries (Large/with gauge, small without gauge) in June 2009. The large battery lasted about 3 months and started holding less and less charge (yellow, then red on...
Batteries must be completely dead before recharging or battery life is shortened.large battery is probably defective contact Ryobi to replace battery they while probably send you new batteries for free if you tell them you are going to stop buy their products.Tell them about both batteries they will probably replace both for no charge
Jun 12, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I cant tell how much battery life i have left the gauge just stoped working
download the widgets of battery meter from the google..
try out genuine one
Mar 10, 2010 | KAOS Systems Damier Game Builder...
How to maximize battery life of a laptop
In addition to all these excellent suggestions don't plug your computer in with the battery installed every time you need to use it. Most manufacturers don't recommend uninstalling the battery (unplugging it) while using it. The truth is, though, this repeated charge and discharge cycle from plugging in your laptop will significantly drain the life of your battery because it is only good for so many charge cycles. So if you're in a situation where you don't need to use the battery unplug it and just use AC power. Also don't always run the battery completely dead when using it. It is best for modern li-ion batteries to be charged to full when they still have 15-20% power still left in them. About every 10 discharge cycles it is best to run the battery completely dead as this will reset the battery meter in the computer so that it can read the available charge more accurately.
Dec 12, 2009 | HP Pavilion dv6000z Notebook
Why does my battery stop charging at 35%?
The battery pack will need to be replaced. It has reached it's full life expectency
Jul 11, 2009 | Computers & Internet
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
Help
Hi, You problem is more than likely a faulty battery or even the charger, you'll need to get these tested to find out what is causing the problem.It is known that the batteries tend to stop charging and need replacing after so long. If you take it into any computer shop they will tell you what is causing the problem as they will have a battery to try, this will tell you if it is the battery or the charger that is at fault. They won't charge you for this as it will take a matter of seconds to test the battery.
Let me know if you need further assistance, remember to always let the battery go totally flat at least once a month and then do a full charge as this will prolong the life of your battery and keep your battery lasting for the maximum time. It is recommened to do this with any electrical equipment that works off a re-chargeable battery, or else it cause bad cells & stops it from being charged.
Apr 25, 2008 | Computers & Internet
Electric Currie EZIP 500 Scooter Logo
140 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Mike Stager
Mike Stager
Are you an Electric Toy Expert? Answer questions, earn points and help others
