most blue tooth manufactures of blue tooth devices use a factory 4 digit pin pairing code now the most common one is as follows but there is a possibility that i could be one of the others i will put them in order from most common to least commmon try them in that order they are 0000,1234,9999,or 1111 i hope this helps
to use the pass code for your blue tooth device you must first put the device into discovery mode then most blue tooth manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. i hope this helps
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
You need to pair your PS3 with your bluetooth headset.
Turn on your PS3's bluetooth and search for bluetooth devices.
While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
Pair the devices and allow the BT headset to connect automatically.
To connect, press and hold call/end button on BT headset like the one in step 2.
yes, okay.. there should be the turn on button on your blue tooth headset, make sure the blue tooth headset is off.. now before you start the scan, hold down the power button for the blue tooth until it starts blinking colors.. usually red and clue, then start the scan, the pass code for the blue tooth will also be 0000, it is for mostly every single one
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
