Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Posted by brian_g700 on
Ernest R
    President:
  • 1,618 Answers
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Posted on Mar 13, 2010
I just got a new Gaggia Synchrony Logic RS from amazon and it only leaks water when we turn it on?
brand new --out of the box-- still covered by warranty --don't fix --contact your supplier and ask for a return of defective item and a refund or a new unit as replacement
Jul 28, 2016 | Gaggia Synchrony Logic RS
Gaggia synchrony logic making grinding noise
With these removable units, you must be very careful, the circular mechanism that does the running of the Y motion need to be properly alligned. You need to perhaps put the back of a knife in it and adjust until all the parts align, Then it must click in easily. If you have forced it in the clip will not release. you need to rattle it a little.
Sep 02, 2012 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
I need to replac steam valve for gaggia syncrony compact, where can I get the parts?
I get parts for my Synchrony from Cerini.
http://www.cerinicoffee.com/Gaggia_parts.asp
There are a couple of different stram valves. Call them to get the right one.
Nov 14, 2009 | Gaggia Syncrony Compact Digital Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
153 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
