Sentry CA 756 Calculator Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There appears to be no carot key on this calculator, how do i find it?
k24674
Level 3:
  • Sentry Master 8,093 Answers
  • Posted on Mar 10, 2010
k24674
Sentry Master
Level 3:
Answers
8093
Questions
0
Helped
4675518
Points
21596
You mean caret ^. This key is the universal power key. It is sometimes represented as Y to the x, or X to the y.
1helpful
3answers
I am using a TI-30 calculator and I am trying to calculate student loan payments. I need to know how to put a negative exponent into the calculator to process the formula. Example: (1+ .0075) to an...
Depending on your version of the TI-30, you will either find a button with a y to the exponent of x or a button that is the carot (^) sign. you would type (1.0075)^(-240), where ^ is the appropriate button (y^x or just ^).
1helpful
Where is the carot symbol on TI 30 XA and is there a chart showing the meanings of all the symbols and how to use them
The power key is marked y^x and is located just above the divide key.
You can download the guidebook which explains everything from
http://education.ti.com/educationportal/sites/US/productDetail/us_ti30xa.html?bid=6
Where is th carot symbol and how do you do to the power of and to the negative power
The key is marked y^x and is just above the divide key.
As an example, to raise 2 to the -3 power, press 2 y^x +()- 3 =
+()- is the key between the decimal point and = keys.
Cube root of a number
push 3
then push 2nd
then push the carot symbol ^ some calculators have this as y^x
then enter your number
If that fails use the calculator program in your computer and change its view to scientific. This has cube roots
1helpful
What do i key in for 2 to power of 12??
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
I want to know how to key in to calculate 2 to the twelveth power to get anser.
You should specify your calculator and avoid posting the same question multiple times.)
Here is the solution for FX-300ES
Hope it helps
The calculator is dead. Batteries are OK.model
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
HP 48GX problem
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Top Sentry Office Equipment & Supplies Experts
k24674
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Office Equipment and Supply Expert? Answer questions, earn points and help others
