SOURCE: sony rm-y181
use this website to get the manual with the codes
http://www.remotecodelist.com/remotes/old-index.html
The manual file that will work for you is under Sony and is named RM-Y165
Let me know if you have any questions or need any more help and I would be glad to assist you
SOURCE: I have Sony Universal remote that I cann't sync or learn commands
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
SOURCE: I need a code for dvd panasonic home theater
Future reference, go to www.Sony.com or even google. The users manual is available online and you can get the codes there.
However, I was bored so I looked them up for you.
the code is 753
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
