If your model has the indicator light make sure it glows bright when the brush roll is spinning. If it isn't as bright or flickers when vacuuming the carpets replace the belt. Be sure to replace belt at least once per year.
yes it should alway be spinning when you switch on the machine, if it's not spinning i would sujest the belt as come off or broke this video will show and explane what you need to do to replace or put back on .
THE IMPELLER LOOKS SHOT.. 25 QUID FOR NEW ONE,,LIFT THE LID AND TURN THE ROUND PIN AND CHECK FOR RIDGES ROUND THE WHITE IMPELLER,,IF NONE THERE THATS IT,, HAPPEND TO ME TEN MINS TO FIX GEORGE
Hello, Check this guide to be sure that your brushroll is in correctly. Follow it step-by-step and it should help of your brushroll spins freely. If it doesn't, there are new brushrolls available through the links in the guide as well.
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
Here is a online guide....it's for the G series Kirbys. They're similar enough that it should help. Pay special attention to the belt lifting process...it's exactly the same as for the Heritage II, and it's also where I think your problem lies. I have a Heritage II manual available too! Hope I have helped...
Marci
