Question about Casio FX-9750GPlus Calculator
How to grahic using casio fx-9750GII - Casio FX-9750GPlus Calculator
Posted by jj8coti on
k24674
  • Casio Master
  • 8,091 Answers
To draw graphs.
  1. Turn calculator ON (isn't that obvious?)
  2. If you see no icons, press [MENU]
  3. Use arrow to move focus on GRAPH and press [EXE]
  4. By default, the graph type is Y=
  5. Enter your equation on line Y1=, use the [X,theta,T] key to enter the X-variable
  6. Press [EXE] when finished entering a function.
  7. Enter other functions if you want.
  8. When done, press [F6:Draw].
  9. If you do not see a big portion of the curve you can press [SHIFT] [F2:Zoom] and select [F5:Auto]
I am enclosing screen captures. The screens you see may not look exactly as on the FX-9750G, but all menu commands you have to execute are accessed by the same key sequences.
This last one is obtained with the Zoom: Auto
Posted on Mar 29, 2010
  • k24674 Mar 29, 2010
    The screen is from an FX-9750GII
How can I change the threshold for scientific notion rounding in normal display mode on my Casio fx-9750GII.
[PDF]fx-9860G Series_fx-9750GII_fx-7400GII_Software Ver. 2.0_Eng - CASIO
support.casio.com/pdf/004/fx-9860GII_Soft_E.pdfThe contents of this user's guide are subject to change without notice. ... For full details on availability in your area, contact your nearest CASIO ...... The calculator normally displays values up to 10 digits long. Values that exceed this limit are .... The fx-7400GII and fx-9750G II are not equipped with a Math input/output mode.
SOLVED: Scientific notation on the casio fx-9750GII - Fixya
www.fixya.com/support/t20210775-scientific_notation_casio_fx_9750gii
Sep 20, 2013 - Press [SHIFT][Menu] to open (Setup). Scroll Up to reach the line Display, press [F2] (Sci), type in the number of decimal digits, press EXE. See the screen captures below. Scientific notation on the casio fx-9750GII
Mar. 13, 2017
SOLVED: How do i turn off the scientific notation
Mar. 30, 2015
Using Scientific notation on the casio fx-9750GII
Oct. 5, 2013
Casio FX-9860G Graphic Calculator Scientific ...
Oct. 18, 2011
More results from www.fixya.com
How can I use scientific notation on casio calculator? ' Socratic
https://socratic.org > ... > Correct Use of a Scientific Notation on a Scientific Calculator 7 days ago - Most scientific calculators have a button EXP ...type in a number, press EXP , AND then you asked to input the exponent as a power of 10 .
videos
casio fx 9750gii scientific notation Google Search
Jun 18, 2018 | Casio Computers & Internet
Hoe to Calculate nPr and nCr on a Casio fx-9750GII?
In Run/Mat screen, press the OPTN key followed by F6, the F3:Prob. The nPr and nCr tab are accessible. Type n then the relevant tab, followed by the r-number.
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
How can i Make a Casio fx-9750gII simplify radicals?
I am sorry, but the Casio FX-9750GII does not manipulate radicals (roots). Maybe you mean fractions?
Feb 22, 2012 | Office Equipment & Supplies
I have a Casio fx-9750GII, how do i switch my radians to degress?
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Jan 19, 2011 | Casio FX-9750GPlus Calculator
What is the better calculatorTI-83 Plus or FX-9750GII
If you have to restrict your selection to one or the other the Casio wins "hands tied behind its back". If you need convincing read on.
Advantages of Casio
Newer technology
About half the price
About twice the Ram
Uses iconic menus
Most screens have tab/menus: No need to scroll.
Conic graphic embedded in OS, not need for an extra application
Dynamic graphing embedded in OS, no need for an extra application
Has a reset button
Several types of statistical graphs that do not exit on TI83 (pie chart)
Ability to select the integration algorithm
Better screen resolution.
Jan 12, 2010 | Casio FX-9750GPlus Calculator
How do I calculate normal distribution using a fx-9750gII?
I don't know about fx-9750gII, but for fx-991MS
Change the mode to REG
Then
Shift->3(DISTR)->1(P())->give your Z value
Jan 07, 2010 | Casio Office Equipment & Supplies
Casio FX-9750GPlus Calculator Logo
313 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
