Question about Schumacher & Fast Charge Starter Charger
Why is it making a humming noise
The charger is plugged into the auto for charging and it making a humming noise
Posted by ckritsky on
Anonymous
    New Friend:
    Problem Solver:
  • 12 Answers
If it is humming ONLY when you connect it for charging and does not hum when you have no load on it...it has too much initial load and the humming is caused by an output current overload.
I don't know what you are trying to charge....if you are VERY careful and you can monitor the output current load....you may be able to get a charge....BUT BE VERY CAREFUL!
Posted on Mar 09, 2010
2answers
How do you charge the unite . I have charge for more then 24 he's.
How old is the battery? Batteries do ware out. Have you had it tested? You can get it tested at most Sears Auto stores for free. If you can take it out of the vehicle and take it to Sears, then you could save yourself some time and money. I am assuming that your battery charger is working correctly. Do you have it hooked up to the right terminals? When the unit is plugged in, does it make a low level humming noise (indicating that it is working)? Does a value register on the gauge?
About 2 weeks ago i noticed a background hum from the alernator as I drove. The noise grew until three days ago when the battery would not turn over. I re-charged the battery and was able to start the
the hum is probably the alternator on its way out and is not charging the battery but check ur belt and make sure not to loose if u drive to one of the local auto stores most of them [like advanced auto-auto zone ]can do a free test on both and advise if replacement or repair needed
The phone has nothing on the display. It was left off the charger all night. It is making a humming noise. It is just the phone that is making the noise when it is on the charger. I have been charging the...
The battery might be bad. Try replacing the battery and if that doesn't help the humming noise also then something is wrong with the speaker in which case you will have to replace you phone.
Just got a used unit and the battery does not seem to charge. When plug charger in light on charger is green. When I attach the battery the light goes off, and charger makes a humming noise. Is this...
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, you can order a new one here www.powerwheelsoutlet.com
24v sds.no lights on charger but making humming sound.all 3 batteries not charging.any ideas?
If it is out of warranty open it up and check the fuse inside. This has happened to me several times with several brands, and it has always been the fuse. They are usually replaceable at Radio Shack or the Auto Parts Store.
Hope this helps!
Jim
Not Charging
Probably the charger has gone bad. You can look on Pridemobility.com for a dealer in your area.
Battery Will Not Charge
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Car charger lights up but phone does not take charge
try charging your fon in your house outlet. if it works then your car charger is defective. if still your fon wont charge in your house then your fon has a prob in its charging section.
Schumacher & Fast Charge Starter Charger  Logo
Top Schumacher Electrical Supplies Experts
Ngoro
john h
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
