Installed deskjet 5650 on win7 laptop windows sees it however whenever and whatever you try to print you get 2 errors invalid handle and Operation could not be compteted ( error 0x0000007a) Have been able to install this printer on several other win7 systems no issue, all systems built from same image.... any idea how to get pass error have tried all the all classic printerdriver fixs nothing works.
SOURCE: error message 0x0000007a
Google HP error message 0x0000007a and see what feeds back. I get the best answers that way
SOURCE: can not install hp deskjet 5650 with Vista operating system?
Drivers for this printer are already pre-installed with Vista.
Power down your PC.
Plug in the printer (wall and PC).
Startup PC - Vista will install the drivers and printer automatically.
Thanks for using fixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: hp5610 printer softwre for Vista 64bit
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a4
SOURCE: I have an HP D5360 printer on a dlink dpr-1260I
I believe your suspicion of driver/Win7 problem is right on target.
Many manufacturers have not created / updated hardware drivers to work
under the new Windows 7 environment - which is much more security focused than past versions have been.
If
the driver you downloaded from HP has not been tested and certified to
work under Windows 7, then you have a slim chance of getting the
printer to work correctly, if at all. If the driver has been tested and
certified by HP, then I would file a trouble ticket with them,
describing the problems exactly. You may have discovered a bug in their
driver that they could not / did not test for.
