Question about M-Audio Audiophile 2496 PCI Digital Audio Card System
Hi, i have an m-audio 2496 sound card and a yamaha mixer but the card doesnt record my sound fro my microphone.. pleaseeeeeeee help
Posted by edmond_tumus on
Jules Peters
  • 702 Answers
Not sure what OS you are using, but here is an article with some ideas on how to fix sound recording problems in Windows Vista.
http://www.pcauthorities.com/multimedia/how-to-fix-sound-recording-problems-in-vista
Posted on Mar 19, 2010
Hi my problem is / I do not hear my microphone -please HELP me !!!
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Jun 03, 2011 | M-Audio Audiophile 2496 Soundcard for...
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
I have a Tascam TM-D1000 digital mixer that has a TDIF output and want to connect this to my computer. Do I need a PCI 822 card or is there another option to connect?
I have a TMD1000 connected to my computer via the RCA ( Red & White) outputs on the mixer to an M-Audio 2496 Sound card in the computer.
also via the Digital out on the mixer to Digital in connector on the card.
I then edit recordings on the computer with Cubase pro.
Nov 28, 2010 | Tascam PCI822 Digital Audio DTRS Interface...
Built in microphone not working
If this is on your pc? Go to Start, Programs, Accesoories, Entertainment, Volume controle. The internal mixer will pop up, go in to options tick recording . and make sure the microphon in the box below is ticked. Then tick ok. the mixer will change in to the recording mixer. You will then see a microphone slider on the internal mixer. Make sure it is up and that the select box box below microphone is ticked.
Regards Mark
Nov 17, 2009 | Toshiba (P000257700) Microphone
How to use yamaha mg102c with m audio usb
You must connect:
the mixer output to the "line|optical" input of the Transit
the mixer input to the line (in case of an analog signal) or to the optical (in case of a digital - optical signal)
The USB connector on the other side is going to be connected at the USB port of the pc.
Just keep in mind that the signal flow goes as the arrows on the Transit.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Sep 05, 2009 | M-Audio Transit USB Sound Card
I plugged a mic to my dell laptop but it isnt working, do i need a sound card?
No, if you have a jack to plug the mic into you have a soundcard. However the mic is probably muted in the mixer software. Go to the control panel, left click on sounds and audio, then click on the advanced button; this should open the mixer in the play back mode, at the top left of the mixer go to options and select properties, a new page will come up with a radio button showing playback or recording, switch the radio button to the recording list and check everything in the checkboxes including the mic and press ok. A new mixer should come up with your recording deviced, from here you can set your microphone device volume.
Jul 01, 2009 | Computers & Internet
Audio Recording Problems
try using the windows sound recorder to see if that records music? if it doesnt then you need to go into your sound recording properties and change it from mic to wave
Dec 02, 2008 | E-Mu 0404 Sound Card
Using the dp-01 as a interface mixer
If you're asking about being able to use the DP-01s knobs and sliders to control the virtual knobs and sliders on some PC recording software the answer would be 'no'.
But if you just want to use the DP-01 to act as a mixer for incoming signals (like microphones and or guitars or other instruments) the answer is 'kind of'. The DP-01 cannot act as a usb interface for your PC, but it can sit in front of a usb interface or sound card and act as a mixer of sorts to mix input from instruments through the monitor outs and then into your computers sound cards or usb interfaces audio-in jacks. You are however limited to two simultaneous inputs though as that is all the DP-01 can handle.
Cheers.
bd.
Oct 20, 2008 | Tascam DP01 All-In-One Recording Package...
Microphone can be detected but doesnt work
Go to start then control pannel then sounds and audio devices. Then in in the volume tab select advanced in the device volume section. When the mixer comes up go to options then properties select the recording option a recording mixer will come up make sure to check the microphone box. Raise the level in the ixer and you should be golden. If you want to hear the mic select playback mixer and raise the mic level. Hope this helps. : ]
Dec 09, 2007 | ASUS P5RD1-VM Motherboard
Sound card driver problem
If you are using xp
Go to control panel
Click on sounds and audio devices
click on voice
See voice playback?
click on volume make sure there is not a check mark in mute under microphone
Do the same for voice recording
and check the volume levels on both
Hope this helps
Oct 20, 2007 | Computers & Internet
Open Questions:
I just installed my M-Audio Audiophile 2496 PCI card (it seems this is part of the Delta series of cards?) in Windows 7 (64-bit) and it successfully registered and installed the driver, but when I disable my old sound drivers in Device Manager (the Realtek ones which is the sound integrated on the motherboard) I don't hear anything and I checked the Audiophile driver settings and see no headphone or speaker devices listed like there was in the Realtek driver. I re-enabled the Realtek driver and it seems my headphone jack is connected to the motherboard so it's using the built-in Realktek sound card. How can I get sound from my Audiophile card to my headphones? Do I have to remove the Realktek drivers completely or can I leave them just disabled in Device Manager? I don't see a Headphone jack labeled on the Audiophile card. First screenshot shows the two Realtek drivers (ATI HDMI Audio and Realtek High Definition Audio) and my M-Audio Audiophile driver in the Device Manager: http://img694.imageshack.us/img694/4369/audiophile1.png Here you can see how I right clicked on the Realtek driver and disabled it. I did this for the other one. After doing this I tried to play a movie and got no sound: http://img715.imageshack.us/img715/9194/audiophile2.png Here is my Control Panel -> Hardware and Sound -> Manage audio devices: http://img132.imageshack.us/img132/4720/audiophile3.png As you can see the Speakers (this seems to be device associated with my headphones) are showing the Realtek driver. When I disable the Realtek driver in Device Manager and then go to this same screen it doesn't even show the Speakers device any longer. BTW my headphones use a 1/8" (3.5mm) jack. I don't see anywhere on the Audiophile card where I can plug them in there are only RCA inputs and RCA outputs and the breakout cable has SPDIF inputs and outputs. None of these will accept the 1/8" jack! HELP PLEASE!
Feb 27, 2017 | M-Audio Audiophile 2496 PCI Digital Audio...
M-Audio Audiophile 2496 PCI Digital Audio Card System Logo
117 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Vernon Taylor
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
