I'm guessing you have the H20-600. They got recalled. More than likely, your receiver is bad.
If your installation was in the last 3 months, do your technician a favor and call him if he left his number or office number. Even though you have a faulty unit, a 'repeat service call' still counts against him and it could effect his work flow. Call them and they will do what they can to help you get a new unit without harming the technician's stats.
If your installation was not in the last 3 months, call DirecTV. This is pretty much a receiver issue (an issue like a bad connection or switch wouldn't cause this problem). You can probably try to get them to directly mail you a new box (you'll be able to ship your old one back for free) instead of forcing you to wait for a service call. If you have the H20-600, you can probably get the box for free but you'd definitely end up paying for the service call.
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
