Washing Machines Logo
Anonymous Posted on Oct 23, 2017
Little AGITATION clothes not getting clean, Spin cycle is fine
Spins but very little AGITATION. Agitates little tiny moves. Maybe 1'' in one direction and 1'' back the other direction, seems slow too. Clothes are not getting clean. what to repair? where to find a manuel. thanks for any info! sherrie
Whirlpool Ultimate Care II LSQ8243HQO Top Loader, Heavy Duty, Super Capacity, Plus - 8cyl /2speed
Robert Freeman
Level 2:
New Friend:
  • Expert 38 Answers
  • Posted on Jan 09, 2018
Robert Freeman
Expert
Level 2:
New Friend:
Answers
38
Questions
Helped
11958
Points
109
Hi Sherrie,
There is a service manual located inside the front left side of the cabinet.I find it easier to turn the washer on it's back and then reach up in the cabinet to get it.Hope this Helps !
5 Related Answers
Anonymous
  • 6784 Answers
  • Posted on Mar 13, 2009
SOURCE: Whirlpool ultimate care II super capacity plus
this is a severed plastic coupler that the drive shaft uses to engage the agitator. this is connected to the clutch and if its stripped or broken, it will not agitate.
Anonymous
  • 56 Answers
  • Posted on May 31, 2009
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Anonymous
  • 5911 Answers
  • Posted on Jul 23, 2009
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Anonymous
  • 278 Answers
  • Posted on Oct 16, 2009
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Anonymous
  • 1937 Answers
  • Posted on Jan 26, 2010
SOURCE: kenmore 80 series washer is making a noise
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
Within the transmission are a set of plastic cams that raise the agitator gear when moving into the spin cycle. If the cams are worn, the gear won't lift high enough (about 1/18") and the gears will grind.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.
Testimonial: "Thanks, this was helpful. Unfortunately, we couldn't locate any broken parts. "
Amana washer. Why is it acting up?
Question edited for clarity, 'Amanda' to 'Amana'.
Question moved to maker category.
It is sensing, and that you have something that needs a 'Delicate' setting, or a 'Woollens' setting. It provides water and very little agitation that might damage or stretch the clothes. Read the manual.
Google
Amana (model) manual
2answers
My whirlpool washer agitates really slow. Clothes are not moving or getting clean. Also doesn't do the final spin. Just drains. If I put it on the drain and spin cycle afterwards, it works just fine.
If it is under warranty have a tech come and check it out. My new WTW5105HW0 is weird. I had to watch it through most of the cycle to figure out what it was doing. They are all software controlled nowadays. :(I like the old ones a lot better.) It used to spin for only 2-3 minutes so the clothes were quite wet and had to do extra spin and drain cycle and still wet.For whatever reason it stopped that and now spins normally (who knows). They say U have to use HE soap, I have a lot of powder left over so I can only use a little bit or else it goes into "Suds Reduction Mode" (and always fails to "reduce the suds" and spits out an error message and that can affect the spin cycle.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Washer washes and wont spin clothes in either the wash or rinse cycle
If you have little to no agitation (as well as spin), look for a broken motor coupling (connects motor to transmission).
If the motor coupling is ok, open the lid and select a spin cycle, insert a flat screwdriver or pen into the lid switch and try pushing the drum along in a clockwise direction. If it doesn't spin or spins slowly then the brake/clutch assembly is slipping and will need to be replaced.
Could I please get a follow-up to this previous issue? I just had one more question, posted on the 30th of October. Thank you!
ok i might have to put this in a 2 part solution it might not be big enough to fit here
i hope this helped you in your washer it still is cheaper to repair than to replace
your washer blew out its thrust bearing which is called the brake
while you have the washer open grease the bearings and oil the motor you can get these same things and intstructions for this to do
this is the thrust bearing kit which you will need the instructions i will post the link and a copy of the pic
http://www.appliancepartspros.com/part_details.aspx?part_id=3728465&pn_=12500036
this is the link to the thrust bearing kit you need to replace to run dryer correctly
5953465.jpg http://www.applianceaid.com/images/thrust_kit_remove.jpgthis are the instructions for thrust kit
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
