Question about Avaya 4610SW IP Phone
Unable to conference in more than one external call using the Avaya 4610 and 4621 IP phone Is there a configuration item to enable this in CMS ?
Posted by johnmcginnis on
Anonymous
  • 33 Answers
The conference is not configured in the cms it is configured in the asa or cm and cms is just for reporting not for configuring any other ip telephony configurations.
Posted on May 24, 2010
Avaya 4610SW IP Phone: Alphanumeric password for extension
The fourth Softkey is alpha and is used to toggle between alpha and numeric entries. "Press the Line/Feature button to the left of the Password."
More information is available on page 48 of this pdf:
http://www.kumc.edu/Documents/Information%20Resources/4610VOIPTelephoneUsersGuide.pdf
Entering Characters using the Dialpad:
http://www.kumc.edu/Documents/Information%20Resources/4610VOIPTelephoneUsersGuide.pdf#G9.494531
Dec 14, 2013 | Avaya 4610SW IP Telephone Grey 700381957,...
Cannot configure extension on avaya ip 5620sw
Is this a Definity, Communication Manager or IP Office?
Press, HOLD, 5 6 4 6 3 3 (LOGOFF) #
If that doesnt work, try: MUTE, 5 6 4 6 3 3 (LOGOFF) #
Nov 27, 2012 | Avaya 5620SW IP Phone 700339815
I am unable to go to configure mode to my Avaya 4606 IP phone, i also tries 73738 (R E S E T) - use to change the phone configuration. 25327 (C L E A R) - unsure how similar to or different from...
Sounds like the phone is working fine. When it displays "Discover 192.168.xxx.xxx" it is looking for the call server (Phone system) and cant find it. Make sure the phones IP is in the same subnet of the phone system. Make sure that the phones IP and the system IP can both be pinged from the network.
Dec 22, 2010 | Avaya 4606 IP Phone
The Avaya 4610sw phone will not find the main phone system an Avaya G350 it has been unplugged from the system and when it was plugged back in it would not find the router or system
It's probably a problem with your DHCP settings, if you try manually setting the IP configuration on the phone it should find the server/control unit, haven't used 46x series myself, but if you reboot the phone at some point it should give an option to configure manually, if you have another working phone you could get the IP configuration off that one, think you can find them somewhere in the option panel on a working phone.
Apr 22, 2009 | Avaya 4610SW IP Phone
I have a Avaya 4690 ip phone. when I reseat the ethernet cables for the phone after initializing it comes up with "registration error". How do I fix that?
That phone is registerring with a server. There is nothing you will be able to do. You need to contact your system administrator
Jan 09, 2009 | Avaya IP Office 4690 Speakerphone...
There is no option for conference calling
What firmware is running on the phone?
Jul 20, 2008 | Cisco 7940 IP Phone
4690 Issues
You have to manually enter the callserver IP address (CLAN card). The 4690 are not in the 46xxsettings file.
Mar 27, 2008 | Avaya For Communication Manager4690 IP...
Discovering
Talk to your system admin. You have a Definity system, which is too complicated for online help. The phone isnt seeing either the license server or the Phone system. There is more than likely an incorrect IP address somewhere.
Jan 22, 2008 | Avaya Lucent 4690 IP Office Speakerphone...
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Avaya 4610SW IP Phone Logo
192 people viewed this question
Top Avaya Computers & Internet Experts
Vincent G
Vincent G
k24674
ray gallant
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
