Question about Dacor ECD230 Epicure Electric Double Oven
SOURCE: My Dacor wont heat, broil or convection after self cleaning
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Posted on May 30, 2007
SOURCE: Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Posted on Dec 07, 2007
SOURCE: what size is the bottom element in a dacor model
I'm sure what you are asking. If you need an element, you can order it by your model number, which you have provided. We supply parts and you are welcome to call us at 9728590929 and we will be happy to assist you with your parts orders. We hope this helps!
Posted on Aug 14, 2009
SOURCE: I have a DECOR Convection oven W305 model and left
Decor manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 21, 2009
SOURCE: oven beeping
yOU NEED TO CHECK THE FAULT CODE F1 MOST LIKELY THIS IS A STUCK BUTTON . HERE IS THE DACOR MANUAL
Jul 28, 2012 | Dacor Ovens
Jun 13, 2011 | Dacor DO130S Oven
Dec 17, 2010 | Ovens
Dec 24, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jan 13, 2018 | Frigidaire 30 in. Electric Gallery Series...
Aug 14, 2009 | Dacor Epicure 30" Double Wall Oven,...
Aug 07, 2009 | Dacor ECS130 Epicure Electric Single Oven
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
283 people viewed this question
