probly age--needs boiling out or jet ajust-------try fixin idle speed with screwdrivr---------cud be engine issue-like tuneup---inspect inside distributer cap for corrosion or worn plug wires---also egr valve mite be bad--------get vehicle scanned
starter is located on the front side of the motor, easiest way to reach it is from underneath just between the radiator and the motor, two 13mm bolts hold it to the transmission
It is by the intake box next to the brake booster....You also need to check and change the fiter on the driver side rear tire fiter ..its small ands its black .
The crankshaft position sensor (POS) is located on the oil pan facing the gear teeth (cogs) of the signal plate. It detects the fluctuation of the engine revolution. After replacement, ECM reprogramming is required. This vehicle may be subject to voluntary recall, CAMPAIGN I.D. # R0606, that involves the crankshaft position sensor:
Quote:
Nissan has determined that on some 2003 - 2004 Altima and Sentra vehicles with the 2.5 liter engine the operation of the crank angle sensor is significantly affected by variations in temperature that occur due to the unique location of the sensor in the engine. Under certain driving conditions, these variations in temperature can be large enough to cause a brief interruption in the signal output from the sensor. If the interruption in the signal from the sensor is so brief that the Electronic Control Module (ECM) logic does not have time to diagnose the condition, the engine may stop running without warning while the vehicle is driven at low speed.
the flasher is under the dash to the left of the steering column, its a relay assembly so a good idea is to get a new one first so you know what your looking for,
the floater or sending unit that's located in the tank has failed. you will need to replace this device. check the fuse before you purchase to be safe.
