Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
If the voltage in h out is 200v is good or bad and the voltage regular is heat?
    New Friend:
  • 6 Answers
You mean the collector voltage on the Horz output transistor is 200 volts?
I would check this by removing the transistor and then measuring the voltage on the board (where the collector or center leg of the transistor is soldered to).
I don't know what kind of tv this is but you should see 130v or 135 volts.
RCA sets you should see 140v. If the voltage is too high replace the voltage regulator.
Posted on Mar 10, 2010
6ya staff
SOURCE:
Hitachi 60EX01B, horizontal picture is off along with the red convergence. Would like to leave set on and take front panel off and adjust accordingly, instead of unplugging and plugging back in. Says 200v...
You should be careful as dangerous voltages are there, if red convergence is off a lot likely bad convergence chips. A lot of the chips will either be good when cold or even drift when hot.
Note that this is a older set and the twenty or so surface mounted caps in the digital convergence which store the adjustments may be failing---usually if good convergence when hot.
Fixed more than a few of these sets.
Oct 15, 2012 | Televison & Video
T.v. power up then shut off
Your set is in High Voltage Shutdown because 1 or 2 problems. If there was a color problem or Convergence problem before the set went out. You should first change out the converg. amps. If no colour problem then check 6810, 7801, 7802 replace with exact parts also look for bad caps high voltage [email protected] change all, power supply and defection board.
Aug 22, 2007 | Philips 55PP9401 55" Rear Projection...
Tip
How to test Flyback Transformer Without taking it off the Boarda) Basically it...
a) Basically it has to be acted upon by a supply voltage of at least 95V
to work.
sample picture:
b) Of course, assuming the horizontal deflection oscillator works, same
with the horizontal drive and horizontal output transistor
sample of H out transistor
It would generate output voltages on the secondary terminals
and 200V line will be active sending voltages to the
Video Drive circuits. Of course high voltage will be generated
ranging to at least 30 KV and there will be voltages on the G2 of the CRT.
c) The easiest test point to look when it is oscillating, is the CRT heater
voltage, the heater lit when flyback is good ( mostly at night times when it
is dark ) and you can hear sounds, too ( if speaker is connected).
• Heater : marked with letter H and H1
• Green Arrow for the G2 voltage
d) Having a B+ voltage reading of 75 V or lesser ( primary pins )
indicates a bad or partially shorted flyback, assuming your
horizontal output transistor and power supply are good & OK.
• These only applies to CRT type TV's.
on Jul 31, 2012 | Philips Televison & Video
Tip
A) basically it has to be acted upon by a supply voltage of at least 95V to...
a) basically it has to be acted upon by a supply voltage of at least 95V
to work.
sample picture
b) of course, assuming the horizontal deflection oscillator works, same
it would generate output voltages on the secondary terminals
ranging to at least 30 KV and there will be voltages on the G2 of the tube.
c) the easiest test point to look when it is oscillating, is the CRT heater
is dark ) and you can hear sounds, too.
here is a sample image
d) having a B+ voltage reading of 75 V or lesser ( primary pins )
sample of H out
on Dec 24, 2009 | Music
Power shuts down after 30 sec.also red light flashes 5 times weather on or off/ sony kp46wt500
5 blinks states faulty on CRT baseboard circuitry where the video signal is amplified. A bad video amplifier IC, loose solder connection or Absence of 200 volts and G2 voltages.If 200v or G2 voltages were not present, look for the resistor block for screen and focus adjustment. try to adjust the screen voltage of each crt...
Feb 15, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba just will not turn on.
Have someone extract the board for you. Replace all high voltage caps [3 or 4]. The voltages are 160v and 250v, with microfarads of 1mf , 2.2mf or 4.7mf. If the cap temp is 85 degrees, replace with 105degrees. I believe this tv would be 8 or 10 years old. Therefore inspect every solder connection for a good ground. You must pay attention and look for these. Be patient and take your time, if you don't see a bad ground or specified electrolytic cap today, you will find it tommorrow. One more cap to check is the 200v 100mf. Yes all of the above are electrolytic caps. This weekend ad this to your honey do's!
Aug 12, 2009 | Toshiba 36A40 36" TV
Replacement for capacitor 120mf/200v
You can use anything from 100 to 150 uF (mf, or mfd) in over 98% of the applications. Most of these caps have a 20% tollerance in their uF value. If this cap is being used as a power supply filter cap, or a bypass cap, the value will not be critical.
As long as the voltage is greater than the required amount it is acceptable. A poplular value would be 100 uF / 250 V. I rarely see 120 uF caps in equipment.
A higher voltage cap will be physicaly larger. This can become a space issue when installing the replacement.
With the new cap, make sure that the polarity is corrent when doing the installation.
Jerry G.
Jun 14, 2008 | Televison & Video
Tv screen went blank. When I unplug and plug back in I here a hissing Lg 42 flatron plus 6 years old.
do you have heater voltage because if you are hearing high voltage you may need to replace a resistor and capacitor in the 200v circuit or you could possibly have a anode not seated right arcing on somthing or a bad flyback
Jun 11, 2008 | LG Televison & Video
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Repair tip
I have not encountered this problem but I can tell you what is happening. The switching power supply transformer might be arching. I would get a scematic for this set and begin to look at the voltages on the Power supply for proper functionality.
Sep 10, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
