Question about Husqvarna Sewing Machines
I have a Husqvarna 19E sewing machine which works well except for the reverse stitch button, it presses in but will not come out,I have tried oiling the mecanism but that does not seem to help. How do you take the mechanism apart ?
Posted by leeth836 on
paj42
    Genius:
  • 1,116 Answers
Try warming the area with a hair dryer.
Older machine tend to accumulate dust and lint and when mixed with old lubricant can gum up.
Posted on Mar 09, 2010
I have a Husqvarna Viking Quilt Designer II that the reverse button does not reverse. It continues to sew forward when I hold and press the reverse button. Thank you for your help.
If, the machine has been sitting, take a hair dryer and heat where the reverse lever is. Try this, it worked on mine. If, that does not work, try cleaning and oiling your machine according to your manual.
Nov 19, 2017 | Husqvarna Sewing Machines
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Husqvarna Classic 100 sew machine , pressed reverse button, now it sew reverse only!!! Please help! i pressed, i hold, turned off and on, nothing....... any ideas?
There is a permanent reverse position on the dial button behind the reverse where the stitch length is located. Check to see if you have positioned the knob to permanent reverse. The setting looks like a "U" turn arrow.
Feb 18, 2011 | Husqvarna Scandinavia 100 Sewing Machine
My reverse stitch doesn't work?
There is a rocker inside the machine the rocks back and forth with the operation of the reverse button. It will stick if it is not serviced regularly. If you have the machine serviced every 2 to 3 years, by someone who knows the machine, everything should work fine for many years to come. Not servicing a sewing machine is something like not servicing an automobile. It will run fine well beyond the recommended service time but when it stops, you will need to spend a lot more money than what you would for a standard oil change.
Feb 13, 2010 | Husqvarna Sewing Machines
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at [email protected]
Jan 25, 2010 | Husqvarna Sewing Machines
How do I program my Viking 980 sewing machine? I can't find my manual & I think this machine can be programmed to stitch a word/phrase at one time, but I can't figure it out.
First touch the "P" button, the #1 will appear in the left digital window. Choose the first letter you want to sew and then push the reverse button, ( the button furthest to the left with the upside down arrow on it) that puts your first letter into memory. Then select your next letter and push the reverse button again. Repeat the process until your word is programmed into the machine.You can start sewing immediately by pressing on the foot control. Pressing the finishing button (Bullseye) before you start to sew, will make the machine tie off each letter so you can cut the joining stitches. Husqvarna may be able to make you a copy of the manual. They can be reached at: 1-800-474-6437 Good Luck
Oct 03, 2009 | Husqvarna Sewing Machines
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
Sewing Machines Logo
420 people viewed this question
Top Husqvarna Sewing Machines Experts
sewcrazyshan
Level 1 Expert
Susan Null Spradlin
Level 1 Expert
Irene Tulloch
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
