Tomtom ONE GPS Receiver Logo
Posted on Mar 08, 2010
How do i correct the time on my TOmTom one.
How do i correct the time on my TOmTom one. It,s a AKUZC C2F7E.
thanks
Perry
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Mar 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
4164
Points
36
I have a 520 & i tap the screen go into change preferences , tap the blue arrow & on the 8 of 8 page i get set clock tap there to open then done & it gives me the option to change time manually
1helpful
2answers
Element HDMI 32 inch. Left half showing picture, right half only showing vertical rainbow lines.
One of 2 things happened here. Either your T-con board is defective and needs changed, or your Panel is defective and you need a new TV.
1helpful
Hi please explain how to set correct time on
According to the manual:
The easiest way to set the time is by tapping the Sync button. Your ONE XL will then take the time from the GPS information it receives.
Hope this is helpful.
2helpful
I have an TomTom 920Go on which I tried to install new maps, however now nothing is working, I tried to run the backup and tried to re-install maps once more. Now only errors are popping up and the device...
I would recommend contacting Tomtom support directly about this, thay are very good.
http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_alp.php?prod_lvl1=141&p_prods=141%2C1959&p_cv=&p_pv=1.141%3B2.1959&cat_lvl1=&cat_lvl2=&prod_lvl2=1959
Feb 17, 2010 • GPS
Map updates. The directions are often incorrect. Device voice and map show me I am at destination then changes to show it is actually a half mile or more down the road. Needs corrections!!!!!!!!! Thanks!
There ar frequent minor map corrections accessible through MapShare. You configure your GPS to accept these corrections. You can selected to accept ALL, or from TRUSTED sources, or ONLY corrections verified by TomTom.
Connect the unit to the computer and download the MapShare corrections. If your map is too old, maybe it is time to get the latest one.
If you have started using your unit not long ago (less than 30 days) you may have the right to a free update. TomTom offers the 30 day latest map guarantee.
Connect the unit to a computer where you installed the tomtom HOME application. Upon registration, HOME will proceed to update your GPS.
1helpful
Tom Tom 130 will not power-up ( no working screen) when power button is activated.
If your device is not starting up properly, follow the steps below:
soft reset:
How to soft-reset my navigation device Answer In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
Cant fix mistakes on tomtom go map tomtom
certain map share corrections can only be reported...some of those corrections are missing streets...please be advised that the maps on your unit are preloaded...the ability to change them is not possible....the errors can only be reported, and then will be added on future map releases..check out the support page for more on map share
8helpful
ERROR: 573/#https://home.tomtom.com/shop/onetimeDeviceUpdates: Error from server: You have an invalid version of the TomTom application installed on your TomTom device. To use HOME you need to install the...
Go to My Computer, then the TomTom drive and click explore. Move your Map folder to the desktop. Then, delete everything on the tomtom drive. Unplug it, plug it back in, and start up Tomtom HOME and install all updates, keep unplugging, plugging back in, and installing updates until there aren't any more updates. Then move your map folder back to where it was on your TomTom drive.
Please rate, Thank you!
4helpful
3answers
Tomtom stuttering
TomTom Home now has a fix which corrects the stuttering problems with the computer voice needed for the 'text to speech' function on the GO720. Simply plug your device into your computer and have it connect with your computer. You should automatically see a large fix available which will correct the problem. Download it as I did, and the problem is corrected.
Tomtom one europe
wrong language and i don't know how to correct it to english.
thank you john t.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
