I want to calculate the size of a hydraulic pump to drive an Orbital steering system and power a front loader on a tractor.The Orbital is a retro fit as the old system never was any good.The loader is a new application ,max lifting 3 ton.I have available 80 hp,min revs 750 max 2500.Many thanks,Tom.
Replacing hydraulic components in heavy equipment like the John Deere Backhoe Loader Model 210C requires careful consideration, as it can impact the machine's performance, safety, and warranty. Here are some important factors to keep in mind when considering a pump replacement:
1. **Compatibility:** Hydraulic pumps are designed for specific systems and applications. The replacement pump must have compatible specifications, flow rates, pressures, and connections to work effectively within your machine's hydraulic system.
2. **System Design:** The hydraulic system of your backhoe loader is designed with specific components that work together. Replacing a pump can potentially disrupt the balance and efficiency of the system.
3. **Flow and Pressure Requirements:** Ensure that the replacement pump can provide the required flow and pressure needed by both the main and steering hydraulic systems. Mismatched flow rates and pressures can lead to performance issues and damage.
4. **Relief Valve and Safety:** Hydraulic systems include relief valves to prevent overpressure. If you're considering a pump replacement, you must ensure that the relief valve settings are appropriate for the new pump's specifications.
5. **Mounting and Connections:** The new pump should have compatible mounting and connection points with your backhoe loader's existing hydraulic system. Modifications might be needed to ensure a proper fit.
6. **Manufacturer Recommendations:** Consult the manufacturer's documentation, technical manuals, and guidelines for pump replacements. They may provide insights into compatible replacements and installation procedures.
7. **Professional Assistance:** Given the complexity of hydraulic systems and the potential impact of pump replacements, it's advisable to consult with a qualified hydraulic engineer or technician. They can assess your specific situation, recommend suitable replacement options, and ensure proper installation.
8. **Warranty and Support:** Keep in mind that modifications or replacements not recommended by the manufacturer could void warranties and complicate maintenance and support in the future.
9. **Testing and Calibration:** After any pump replacement, thorough testing and calibration are essential to ensure the hydraulic system operates safely and efficiently.
Remember that modifying heavy equipment like a backhoe loader requires expertise and knowledge in hydraulic systems. Any modifications should be carried out by professionals who are experienced in working with such equipment. It's recommended to involve the manufacturer or authorized service providers to ensure that any modifications are done correctly and safely.
If the tractor suddenly quit,the hydraulic pump shaft might have broken,( due to misalignment) with engine...
if the engine the pump must also runs.if it brakes entire system fails
hence the result.
contact..
with regards,
jaijith
Yeh I think your on the right track with the hydraulic pump, if it's power shift as well it stands to reason that the pump has failed, you can fit a guage to the coupling on the rear of the tractor and it will tell you if the hydraulics are working to pressure, hope this helps
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help. Steve
power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
The relief valve may be by-passing, or your pump is cavitating..If you can hear a hissing... its the relief...if you hear whining or chuttering sounds... it is the pump cavitating.It sounds much like a power steering pump. Check your fluid level. **Note There may be water in the system if the oil is really milky looking, also from the cavitation of the pump which causes air in system. And then....Go from there or ask more.
